STD Tuning Engine IP Full Load Adjustment Procedure for the MW and M pumps
  • 14 Vote(s) - 3 Average
08-02-2010, 06:40 PM #101
(08-02-2010, 11:03 AM)garage I plan on very soon modifing a w115 N/A intake to fit the om616..im sure that would be the ideal choice correct?
No difference. The W115 manifold is the same as your stock manifold except for bending upwards instead of straight out.
09-12-2010, 12:30 PM #102
(08-02-2010, 06:40 PM)ForcedInduction
Well the fact the the w115's runners bend upwards causes more velocity right? And its further away from the exhaust manifold.
Its also more spacious in the engine bay.
This post was last modified: 09-12-2010, 12:33 PM by garage.
09-12-2010, 03:45 PM #103
ooo spacious-ness is nice! Big Grin
09-12-2010, 07:00 PM #104
(09-12-2010, 12:30 PM)garage Well the fact the the w115's runners bend upwards causes more velocity right?
No. Any change in direction causes restriction to flow.
11-08-2010, 10:28 AM #105
Pyrometer info added to the first post at the request of smoke026.
BSharp
11-15-2010, 10:38 PM #106
I adjusted the ALDA on my 602 87 190D turbo. Is there a chance of running the EGT up too high? I also added a boost controller and set it to 14 psi.
1987 190DT
BSharp
1987 190DT
11-15-2010, 10:42 PM #107
The ALDA has no effect on EGTs at full boost.
14psi is too high, you don't need more than 12psi. More than necessary just increases drive pressure.
BSharp
11-15-2010, 10:54 PM #108
(11-15-2010, 10:42 PM)ForcedInduction The ALDA has no effect on EGTs at full boost.
I thought stock PSI was 12.5-13 psi. for the 602
1987 190DT
BSharp
1987 190DT
11-15-2010, 10:58 PM #109
Stock is 9psi, the factory max spec is up to 12psi.
BSharp
11-15-2010, 11:25 PM #110
(11-15-2010, 10:58 PM)ForcedInduction Stock is 9psi, the factory max spec is up to 12psi.
Before I added the boost controller it would go to 12-12.5 all the time. Looks like it was at upper end of stock spec. Thanks
1987 190DT
BSharp
1987 190DT
11-16-2010, 08:02 AM #111
Other than beneficial ones Big Grin
NADC 300TD
Cat fixer guy
10
02-24-2011, 09:25 AM #112
I have a dumb question. What difference did taking out the rack have on fuel mileage?
Thanks
Alex
1980 300TD Straight Piped
2001 Chevy 2500HD DURAMAX, Straight Piped, Programmer, Lift Pump.
[Image: nadc-01-duramax-albums-ar-picture2958-a.jpg]
NADC 300TD
Thanks
Alex
Biohazard
Smokin like a champ!
376
02-24-2011, 10:56 AM #113
None for me. Taking out the rack limiter only changes the amount of fuel at full-throttle. If you can keep your foot out of it, it won't affect milage at all. Big Grin
Biohazard
NADC 300TD
Cat fixer guy
10
02-24-2011, 11:03 AM #114
(02-24-2011, 10:56 AM)Biohazard None for me. Taking out the rack limiter only changes the amount of fuel at full-throttle. If you can keep your foot out of it, it won't affect milage at all. Big Grin
Thanks for the info
Alex
NADC 300TD
Thanks for the info
Alex
03-19-2011, 05:34 PM #115
The TC is a mother to adjust without a socket while the filter housing is on... So are the High Idle screws
03-20-2011, 05:27 AM #116
Another good reason to leave the TC alone.
03-21-2011, 03:24 AM #117
Well, looks like I'm going to have to play with it. Removing the rack limiter did absolutely nothing... Still no smoke at any time besides a WOT rev in park.
03-21-2011, 03:50 AM #118
You have other issues. Removing the rack limiter produces an instant 20hp increase above 2500rpm when the boost is raised to match.
03-21-2011, 02:23 PM #119
Well there was a huge vacuum in the tank last night so that was part of it... Boost is @ 12psi
03-21-2011, 11:17 PM #120
Check fuel supply pressure. It should be at least 15psi at WOT above 4000rpm.
dieselboy
Rotatin 5500 times a minute
680
03-21-2011, 11:42 PM #121
my rack limiter did nothing also
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
03-23-2011, 12:34 PM #122
Rack limiter will do nothing until you hit the top end. If it did nothing at all your pump probably could use a bench test.
03-23-2011, 03:47 PM #123
What do you consider "top end"?
03-23-2011, 08:23 PM #124
(03-23-2011, 12:34 PM)winmutt Rack limiter will do nothing until you hit the top end.
Incorrect. It increases fueling across the entire RPM range.
03-23-2011, 11:10 PM #125
Ok well overall its better, just not as good as I had hoped for.... need to make a TC socket...
I also need an EGT before I push it. I keep it at short burst right now so nothing gets hurt.
This post was last modified: 03-23-2011, 11:12 PM by Captain America.
03-24-2011, 09:13 AM #126
(03-23-2011, 11:10 PM)Captain America Ok well overall its better, just not as good as I had hoped for
Whats better than "across the range"?
If you want more power above that range you need to adjust the governed RPM, not torque control.
This post was last modified: 03-24-2011, 09:14 AM by ForcedInduction.
03-24-2011, 11:23 PM #127
(03-24-2011, 09:13 AM)ForcedInduction Whats better than "across the range"?
Moar!
(03-24-2011, 09:13 AM)ForcedInduction If you want more power above that range you need to adjust the governed RPM, not torque control.
your talking the high idle screw?
Moar!
dieselboy
680
03-24-2011, 11:49 PM #128
Why would he adjust the governed rpm? He doesn't want to rev higher he wants more power. I havent touched my governor
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
03-25-2011, 12:37 AM #129
(03-24-2011, 11:49 PM)dieselboy Why would he adjust the governed rpm? He doesn't want to rev higher he wants more power. I havent touched my governor
Where is the     Button lol
03-25-2011, 09:01 PM #130
(03-24-2011, 11:23 PM)Captain America your talking the high idle screw?
Yes.
Quote:Why would he adjust the governed rpm? He doesn't want to rev higher he wants more power.
Boy, increasing the high idle screw raises the RPM where fuel begins to get cut off. Instead of fuel tapering off starting at 4200rpm to zero at 4800rpm it can make full power up to 4800rpm.
Quote:I havent touched my governor
You are a liar. Your videos and post comments prove you've altered it.
This post was last modified: 03-31-2011, 07:13 PM by ForcedInduction.
Yes.
03-26-2011, 03:12 PM #131
Cool Forced. That's what I want to do. I can feel it start to taper around 42-4300 and the fuel CUTS off hard at 4700 or so
03-27-2011, 07:33 PM #132
Which way does the high Idle screw need to be turned?
03-28-2011, 02:29 AM #133
CW increases spring tension and raises cutoff rpm.
03-28-2011, 03:28 PM #134
Thank you sir..
Thank you sir..
led-panzer
03-28-2011, 08:54 PM #135
I see on the M pump that the high idle goes up 150 rpm for every half turn, is it the same for the MW?
This post was last modified: 03-28-2011, 08:58 PM by led-panzer.
1985 300D 280,000 miles RIP
led-panzer
Degen
03-29-2011, 06:22 AM #136
Hi there!
Can someone help me to point out where to do what on my pump?
I cant find any picture on this forum thats exactly the same as mine so im just sending you some!
There are some thats similar but i wanna be sure on this before messing with the pump!
Thanks!
/Degen
Degen
Hi there!
Thanks!
/Degen
babymog
03-29-2011, 11:43 AM #137
The 10mm allen at the top of the first photo is the high-idle setting. 1 turn clockwise/tighter is approximately 150rpm increase.
'87 300TDT "Pandora"
Garrett T-30 .55 @ 18.5psi, .970 IP @ 13.5ATDC turned up, #22 head with oblique injection, 4-puck brakes, 215 Michelins on 16x8" Bellos, updates etc.
http://www.youtube.com/watch?v=RZCI0BTWKx8
babymog
04-06-2011, 04:32 PM #138
Where did all the text go in the first post?
04-06-2011, 04:38 PM #139
Somebody else must have all that copied and saved.
If so, please put it up.
04-06-2011, 04:47 PM #140
I'm surprised that winmutt didn't disable old editing like they did at peachparts, for this very reason.
If you're wondering what happened, FI took his ball and went home. Probably why he got banned.
04-07-2011, 03:54 PM #141
Should I change my avatar now???
dieselboy
680
04-07-2011, 05:02 PM #142
(04-07-2011, 03:54 PM)Captain America Should I change my avatar now???
Lol
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
Lol
-Jesse
70 f250 390
66 Volvo amazon
polarisrmk
603 95' 124 WAGON
78
04-07-2011, 10:38 PM #143
the directions are still on peachparts.
polarisrmk
OM616
10mm MW
572
04-08-2011, 02:50 PM #144
(04-07-2011, 10:38 PM)polarisrmk the directions are still on peachparts.
Friendly warning about the directions for a Torque Control adjustment on a MW IP with an RW governor. I am not interested in saving anyone from anyone, that being said, his directions can result in the lack of a good return to Idle after the adjustment.
To give everyone a reference, after explaining how to set the Idle after a TC adjustment, one gentleman had his TC at 6 turns in, and following my directions, was able to get a good return to idle.
I have also had 7 members of different forums bring me their cars to get them to Idle properly after following the instructions that were posted.
If there is any interest, I am willing to work with the moderators to correct the directions, which will allow the user to be able to actually set the rate, (how quickly), the engine returns to Idle, this is nice for manual transmissions.
OM616
04-09-2011, 11:01 AM #145
I think that would be a great idea om616
04-11-2011, 09:46 AM #146
Does anyone else have a drop in top end with the TC adjustment?
04-12-2011, 03:16 PM #147
(04-08-2011, 02:50 PM)OM616
Please Post!
Please Post!
04-13-2011, 03:21 PM #148
OM616 it's not nice to taunt!
04-13-2011, 04:12 PM #149
Don't nag him. We'll recreate the thread when we recreate the thread.
04-13-2011, 04:53 PM #150
Ok, Ok. Sorry haha
Ok, Ok. Sorry haha
 98 Guest(s)
 98 Guest(s)
