STD Tuning Engine Dodge sprinter engine into a W126
Actros617
What's a spark plug???
49
08-18-2010, 12:46 PM #1
I was wanting to know if this setup will work on W126 with a OM 647 2.7 I5 turbodiesel or OM642 3.0L V6 turbodiesel
Actros617
HughF_UK
08-18-2010, 03:01 PM #2
Only if you're super good with getting the wiring loom ecu etc etc out of the sprinter!
HughF_UK
08-18-2010, 04:06 PM #3
Fitting the engine is very easy, getting the computers to play nice is the challenge.
Actros617
49
08-19-2010, 12:14 PM #4
Yeah i never thought about the wiring, but i shouldn't be that bad if your transfering everything from van to car
Actros617
HughF_UK
08-20-2010, 01:46 AM #5
the problem I forsaw was the whole immobiliser ecu talking to the engine ecu talking to the gearbox ecu situation, all over canbus, with no idea what the signals would be?
I thought about getting a w210 320cdi and putting that in my 201 but abandoned the idea for the same reason.
HughF_UK
tomnik
08-20-2010, 03:09 AM #6
the sprinter is easier because of less "blocking" ecu components.
Tom
(08-20-2010, 01:46 AM)HughF_UK the problem I forsaw was the whole immobiliser ecu talking to the engine ecu talking to the gearbox ecu situation, all over canbus, with no idea what the signals would be?
tomnik
Tom
Greg-MT
10-22-2010, 05:18 PM #7
I have fit an OM647 Sprinter 5 cylinder into a Vixen 21 Motorcoach. Mounts, brackets, custom flywheel, trans adapter are done and perfect.
I can't break the immobilizer. Silly me.
I've broken GM and Chrysler VATs for our Winnebago engine conversion (www.lesharo.com) with no problem. I've worked on Mercedes and BMW since 1965 but I need help on this one.
Can anyone help with the Bosch immobilizer issue??????
Does anyone know if there are Sprinters produced for Commercial Fleet purposes or maybe central Africa the come WITHOUT the immobilizer?
Any help is appreciated.
Regards,
Greg
406.587.8148
info@vixenrv.com
Greg-MT
Regards,
Greg
406.587.8148
info@vixenrv.com
HoleshotHolset
10-27-2010, 02:47 PM #8
I can't help much on the immobilizer except to say that running an aftermarket standalone ECM will cure that problem in a roundabout way.
Which transmission are you running behind that OM647?
I'm in the process of engineering a method of bolting up a GM 4L80E in my W210/OM606.
Thanks,
Matt
'07 W211 OM642
HoleshotHolset
Thanks,
Matt
'07 W211 OM642
sugrmil
11-14-2010, 09:45 PM #9
I don't know about the mercedes specifically but I know that the bosch immobilizers in volvos can be immobilized by shorting two pins together.
I will search for immobilizing immobilizers tomorrow
greg
sugrmil
greg
 9 Guest(s)
 9 Guest(s)
