transmission adj ?
transmission adj ?
I have recently replaced all my vacuum lines and still have symptoms of late shift. I have tried locating the adj knob on the tranny shown here in this link but cannot find it.
<!-- m --><a class="postlink" href="http://www.mercedesdismantlers.com//722.118_transmission_adjustments.html">http://www.mercedesdismantlers.com//722 ... ments.html</a><!-- m -->
any help on where exactly it is located would be greatly appreciated as I still haven't been able to make myself sell it( I am still deploying but pulled her off ebay to continue driving as long as possible, and my even have my dad keep it for me while I am gone)
also I have checked my system and have NO leaks according to my vacuum gauge
-thanks
yes i have... but what is the spec for it?
oh yea its an 85 300d
ncturbo300d oh yea its an 85 300dOh right, that changes everything. Does cruise and climate control work properly. Is it only shifting late? Did you check the position sensor relay on the valve cover?
winmuttncturbo300d oh yea its an 85 300dOh right, that changes everything. Does cruise and climate control work properly. Is it only shifting late? Did you check the position sensor relay on the valve cover?
just checked position relay and the wires are pretty frayed/cracked... good choice of culprit?
ncturbo300d just checked position relay and the wires are pretty frayed/cracked... good choice of culprit?Check em with am multi meter. That switch acts the same as the 3/2 valves in earlier models which will affect shifting.
winmuttncturbo300d just checked position relay and the wires are pretty frayed/cracked... good choice of culprit?Check em with am multi meter. That switch acts the same as the 3/2 valves in earlier models which will affect shifting.
