W123 stuff for sale
W123 stuff for sale
2X map reading dome lights $30 each shipped lower 48 Fits later 123 and early w126. Rare option
2xsubframe mounts $15 shipped
2-3x vacuum headlight adjustment switch $10 shipped
1x manual trans pedal cluster $40 shipped.
1x cracked fire ext mount, $10 shipped
Older Vac pump rebuild for 616 $50 shipped
Newer style vac pump rebuild kit + used pump $80 shipped
Wood and euro ashtrays $15 shipped
Euro upper center console button cover $10 shipped
Older style glow plug relay, unknown condition probably works pulled at jy, $10 shipped
Fed taillight assembly $25 shipped
Fed front psas turn signal $15 shipped
Warngerat 001 545 8232 $10 shipped
Misc relay 107820 01 10 $5 shipped
85 300d cpu 0008221103 egr comp $10 shipped (some other comp is attached as well)
pre 85 sunroof motor $15 shipped
window lift motor $15 shipped
trans pan gasket 1262711180 $10shipped
om616 valve cover gasket $10 shipped
Everything is OBO come haggle.
Here is whats left :
1X map reading dome lights $30 each shipped lower 48 Fits later 123 and early w126. Rare option
Fed front pass turn signal $15 shipped
brown med kit $10+shipping
