STD Maintenance General did someone manage to put new style glow plugs on my engine?
stan
09-18-2010, 05:10 PM #1
my glow plug light has been blinking after i start, which i understand to mean "hey there's something wrong with your plugs!"
what i see in there does not appear to be the larger bodied loop style plugs. the car is a 1980 300TD and the engine number is 617912 12 108470. as far as i know it *should* have the old style plugs. but it doesnt.....
[Image: IMG_20100918_144902.jpg]
[Image: IMG_20100918_144925.jpg]
so are these the newer style pencil plugs, and does that mean i can order those for a replacement? i'm pretty sure yes now because i just checked and there is continuity between the wired heads of the plugs and ground....
stan
09-18-2010, 05:18 PM #2
Those are the new style plugs. The wagon got a lot of things first (after the SD).
Retrofit pencils have the large diameter body. Could also be the head was swapped at some point.
This post was last modified: 09-18-2010, 05:19 PM by ForcedInduction.
stan
09-18-2010, 05:21 PM #3
since i need to order replacements, what do i do? is there a way to be sure the newer style fits properly and this isnt some janky conversion?
stan
09-18-2010, 05:24 PM #4
Pull one out.
Pull one out.
stan
09-18-2010, 05:40 PM #5
(09-18-2010, 05:24 PM)ForcedInduction Pull one out.
i was hoping you wouldnt say that. it looks damn near impossible to get my baseball mitts into there. i guess i'll go do that now.
stan
09-18-2010, 05:44 PM #6
Just look at the body of it where it goes into the head dude
its the normal pencils. you can tell in your first pic
This post was last modified: 09-18-2010, 05:45 PM by Captain America.
stan
09-18-2010, 06:02 PM #7
[Image: IMG_20100918_155808.jpg]
whaddaya know! pencil plugs
stan
09-18-2010, 09:09 PM #8
Both of my 1980 240d have the pencil plugs
09-18-2010, 09:35 PM #9
(09-18-2010, 06:02 PM)stan whaddaya know! pencil plugs
In that picture, is it just the pic, or are the threads as damaged/flattened looking as they appear?
stan
09-19-2010, 03:31 AM #10
(09-18-2010, 09:35 PM)dropnosky In that picture, is it just the pic, or are the threads as damaged/flattened looking as they appear?
just the pic. that one is actually in really good shape.
stan
09-20-2010, 01:15 PM #11
FWIW there are so many part numbers for the glowplug relay its mind boggling. Sometimes they changed 2x in one year!
 10 Guest(s)
 10 Guest(s)
