STD Tuning Engine cw or ccw for wastegate screw?
09-19-2010, 09:09 PM #1
I googled it but, cannot figure it out. I have access to it now as I am trying to break loose the bolts on my alternator and have take out the air cleaner box. If I want to get more boost which way do I turn that thing?
and how much is 'safe' like half a turn? two turns?
-lars
-lars
Rudolf_Diesel
Ask me if I care...
09-19-2010, 11:10 PM #2
If you tighten the screw CW it will load up the spring and require more force to open the Waste gate...give it few turns and try it out.
Rudolf_Diesel
09-20-2010, 01:24 AM #3
CW to increase. One complete turn is worth 1-1.5psi boost.
09-20-2010, 08:59 AM #4
^^ thanks guys.
Also, there seems to be oil spilled all about the connection of that little hose there at the wastegate. I have replaced the hose.
What could that be a sign of? maybe just an old leaky hose. But, why should there be oil in the intake manifold?!
[Image: wastegate.jpg]
This post was last modified: 09-20-2010, 09:01 AM by larsalan.
^^ thanks guys.
09-20-2010, 12:46 PM #5
Witch screw are you adjusting? that looks like a garret???
09-20-2010, 01:20 PM #6
(09-20-2010, 08:59 AM)larsalan ^^ thanks guys.
Blown turbo, leaking oil separator (oil on airfilter)? That model is a PITA to modify, I would get a manual boost controller.
09-20-2010, 01:32 PM #7
That's just an image I pulled of the net
here
http://www.serenitysys.com/MB/Service_In...turbo_.htm
But that's what I have under the hood.
Blown turbo-- I can here and feel mine working
Leaky oil separator on air filter. -- Yeah, there is a bunch of oil in my air box.
manual boost controler-- Huh? I don't have a pyro or MAP. Also, pretty strapped for cash right now. Just thought I could open up that thing in the pic and tighten the wastegate a smidgen.
here
09-20-2010, 02:03 PM #8
You can open it up, its a PITA even with a third arm and 11 fingers. The $10 cost on a MBC is well worth the saved hours and cursing.
Leak oil separator, pull the tabs up, pull the top off, clean well, reseal with black RVT, put lid back on push tabs down, wait overnight. No more oil mess.
09-20-2010, 02:18 PM #9
(09-20-2010, 02:03 PM)winmutt You can open it up, its a PITA even with a third arm and 11 fingers. The $10 cost on a MBC is well worth the saved hours and cursing.
Awesome advice.
Can you explain more about the $10 mbc? What would I need to do with the wastegate? Loosen it all the way down? Remove it?
Where do I get one? like that right.
http://cgi.ebay.com/ebaymotors/High-Qual..._500wt_976
I did clean out the oil separator thing by bending up a tab. It was not sealed in any way.
you mean use a rtv silicone to seal it?
http://www.acehardware.com/product/index...=109369717
the part that is like the size of a soup can lid with a tube coming out the top, right?
thanks in advance
-Lars
This post was last modified: 09-20-2010, 02:49 PM by larsalan.
Awesome advice.
thanks in advance
-Lars
09-20-2010, 04:26 PM #10
Taking off the cap is easy. All you need is a pen screwdriver or a pick. Oil is completely normal due to recirculation of crankcase gasses.
09-20-2010, 04:54 PM #11
So forced you're not in favor of the idea to get a boost controller?
09-20-2010, 05:15 PM #12
Why spend $12 when you only need $0 to get the same result?
This post was last modified: 09-20-2010, 05:15 PM by ForcedInduction.
09-24-2010, 01:05 PM #13
You must have smaller hands or better tools. It took me hours to get that *)&)&)&) clip out. $12 makes it so you never have to take the clip out again. I dunno give it a try, if its easy for you all the better. If the air filter is getting oily seal the seperator. Cheap and easy fix.
09-24-2010, 01:16 PM #14
(09-24-2010, 01:05 PM)winmutt You must have smaller hands or better tools. It took me hours to get that *)&)&)&) clip out. $12 makes it so you never have to take the clip out again. I dunno give it a try, if its easy for you all the better. If the air filter is getting oily seal the seperator. Cheap and easy fix.
I did make an adjustment to the wastegate screw. It was rough to get the tang out and even rougher getting it back in.
I could see both opinions being valid. The cheapskate vs. the uncoordinated.
09-25-2010, 08:33 PM #15
Ya I misspoke. Getting it out easy. Putting it back in was maddening.
 12 Guest(s)
 12 Guest(s)
