STD Tuning Engine Injection noice on om606 with myna pump
350SDL
Fuel of Satan
12
09-26-2010, 01:32 PM #1
Anybody having any experience with injection noice on om606 with myna pump, the noise is from about 2500 to 3000rpm. on light to medium throttle ( normal highway driving ) it is a " tik - tik" sound almost like a bad valve lifter. can it be caused by wrong ip timing.?
350SDL
E300TSC
Turbo-Supercharged
321
09-26-2010, 08:37 PM #2
Can you hear the sound when you raise the RPM's and the car is parked?
E300TSC
350SDL
Fuel of Satan
12
09-26-2010, 11:53 PM #3
only a little sometimes. ( depends on the outside temprature, engine temprature.. ect. ) if i drive at 2500 - 3000rpm. with light load the noise i the worst
if i lift the gas pedal the noise is gone, and if i floor it the noise disepear as soon the boost rise.
350SDL
09-27-2010, 01:01 AM #4
Kind of like Jeemu's?
(at 35seconds)
This post was last modified: 09-27-2010, 01:02 AM by ForcedInduction.
(at 35seconds)
350SDL
Fuel of Satan
12
09-27-2010, 02:08 AM #5
yes it is the same, but mine is not so bad...
350SDL
09-27-2010, 02:34 AM #6
I believe his is from having very advanced timing to get all the fuel burned 5000-7000rpm. Larger plungers also mean the fuel is injected in a shorter period of time which is like advancing the timing as well. Try backing of your timing 1-2*.
This post was last modified: 09-27-2010, 02:36 AM by ForcedInduction.
350SDL
Fuel of Satan
12
09-27-2010, 03:08 AM #7
Thanks. I will try to play a little with the IP timing
350SDL
