STD Tuning Engine Turbo on a 606...
Turbo on a 606...
Turbo on a 606...
henriksen81
09-27-2010, 01:42 PM #1
Hei
I just bought an original turbo and diesel pump from a 97 mercedes 300 turbo and I want to install it on my 606.910 engine. it's a 94' 300td.
Does anyone know if I can use the original Pump and if not, is it difficult to install the turbo-pump?
henriksen81
Hei
09-27-2010, 04:21 PM #2
Yes using the turbo pump would be difficult. It's electronic, there's some electrical box that goes with it, and the pedal is connected to a position sensor.
You can use the original pump but you will not get much power boost.
09-27-2010, 06:21 PM #3
94 should be mechanical, you just need to turn it up and replace the ADA with an ALDA.
E300TSC
Turbo-Supercharged
321
09-27-2010, 07:23 PM #4
Hi, technically, you can have the 6mm elements traded from the '97 pump into the '94 and the pump modified as stated with the ALDA for turbo duty. You'll end up with over 175 HP for your trouble.
E300TSC
henriksen81
09-28-2010, 01:22 AM #5
Thanks for the replies!
I think I will start with just the original pump, just to see if it gives me some more power at all. With an intercooler it should give me a little extra.
Can I use the ALDA that comes with the turbo pump?
henriksen81
E300TSC
Turbo-Supercharged
321
09-28-2010, 05:45 AM #6
Sorry, there's no ALDA on the turbo. It's all electronic...
E300TSC
