STD Maintenance General IP Drip Tube
IP Drip Tube
IP Drip Tube
09-27-2010, 09:50 AM #1
Ok, So I've looked around and can't seem to find a place to buy one. I'd rather buy one made, like the one I've seen from El Paso Tool, then destroy a whole line to make one.... Where do you get one now?
Rudolf_Diesel
Ask me if I care...
09-27-2010, 11:32 AM #2
(09-27-2010, 09:50 AM)Captain America Ok, So I've looked around and can't seem to find a place to buy one. I'd rather buy one made, like the one I've seen from El Paso Tool, then destroy a whole line to make one.... Where do you get one now?
I have one you can borrow, I made it from an old line I got from the junkyard.
Rudolf_Diesel
09-27-2010, 11:52 AM #3
Thanks for the offer Rudolf, I may take you up on that but I would really like to have one to keep for myself... IP adjustment with the tube seems so easy and since idk how stretched my timing chain is I think I will be doing it more than once or twice. Seems like a job that only take a couple minutes...
09-27-2010, 06:37 PM #4
Do like he did, make one from a junkyard line. Bonus points if you make one out of a line some rat mutilated getting to the injectors/glowplugs.
09-27-2010, 06:48 PM #5
Ha, it would cost me more to make the trip plus entry fees and all that garbage. Otherwise I would
BRABUS
09-28-2010, 09:25 AM #6
(09-27-2010, 06:48 PM)Captain America Ha, it would cost me more to make the trip plus entry fees and all that garbage. Otherwise I would
Hello
Can someone pleas post a pick of a IP drip tube? I want to make my ownSmile
BRABUS
Hello
09-28-2010, 09:58 AM #7
Rudolf is sending me one! Thanks dude!
totaldisaster
lightly modded OM606
211
09-29-2010, 04:06 PM #8
You could just use a regular inj line.
the pointy tip helps reduce the tendency of a drip to stick to a tube.... but drip timing timing isn't exactly accurate anyhow.
totaldisaster
09-29-2010, 05:33 PM #9
Well its the most accurate way to time the ip especially if you need or want to advance it further than stock right? Or is there a better more accurate way? Not looking to spend a million dollars here....
totaldisaster
211
09-29-2010, 05:51 PM #10
there are more accurate ways... but not really necessary. Mechanical diesels have been done this way for a very long time.
if you had a new / rebuilt engine or maybe some heavy upgrades like turbo and fuel, then I might want to use a luminosity probe. Or the Other MB methods that require special tools.
I am quite satisfied with drip timing since I advance it slightly beyond factory anyway.
This post was last modified: 09-29-2010, 05:52 PM by totaldisaster.
totaldisaster
09-29-2010, 06:03 PM #11
Yeah I totally forgot to check timing chain stretch when I adjusted the valves but I would like to ahead and see were it is and then set it @ 26 degrees.... im hoping that this will help the grey smoke issue and depending on where the timing is at now may also help the starting issue as I have eliminated all electrical possibilities.
10-01-2010, 11:18 AM #12
Yeah, Got A drip Tube from Rudolf! Thank you sir.
bricktron
'77 240D
174
11-05-2013, 02:35 AM #13
how to reproduce this? ... is the design published somewhere? is it as simple as an overhand bend with an aperture of a certain diameter?
This post was last modified: 11-05-2013, 02:36 AM by bricktron.
bricktron
11-05-2013, 08:59 AM #14
(11-05-2013, 02:35 AM)bricktron how to reproduce this? ... is the design published somewhere? is it as simple as an overhand bend with an aperture of a certain diameter?
I have had good luck using an old injector line from a 60's allis chalmers, bent and cut similarly to the one in the photo.
After timing, run the engine-if it knocks you're too far advanced. If it smokes, lugs, and has high EGTs you're too far retarded
11-05-2013, 01:22 PM #15
Yeah I just grabbed a couple lines from the junkyard, bent, and cut.
