STD Tuning Engine 94 mod. diesel pump tuning?
henriksen81
10-03-2010, 07:23 AM #1
Hello.
Can anybody tell me if there is possible to increase the diesel amount in a 94 mod. pump? It's a 606.910 engine...
henriksen81
Hello.
10-03-2010, 08:08 AM #2
Yes, but you need a way to get more air first.
henriksen81
10-03-2010, 08:14 AM #3
(10-03-2010, 08:08 AM)ForcedInduction Yes, but you need a way to get more air first.
Thanks for the reply!
The extra air would be a stock turbo from a 97' E300TDT. I also have access to a holset hx30 that I might want to try out, but for now I just want to see if I can get the engine to work ok with just adding the turbo and tuning the pump...
henriksen81
10-03-2010, 08:18 AM #4
Then read the sticky thread here: http://www.superturbodiesel.com/std/ip-f...t-189.html
henriksen81
10-03-2010, 08:22 AM #5
I've already read it! Thanks. I thought I had a different IP on my car so I wasn't shure If I could do it on my pump.
henriksen81
10-03-2010, 08:27 AM #6
You should have a mechanical M-Pump like earlier cars. 1996 and up model years need a computer to increase fueling.
Be careful with that stock turbo, its extremely small for the engine and can't make more than 8-12psi safely. You'd be much better starting with that HX30.
This post was last modified: 10-03-2010, 08:27 AM by ForcedInduction.
henriksen81
10-03-2010, 08:39 AM #7
Thanks for the tip. Yes the turbo is extremely small. Anyway.. It's gonna be a fun little project for me as I'm totally new with diesels. Gonna post a thread on it when I start to work on it.
henriksen81
