STD Tuning Engine Torque Specifications
Patrick
Greaser
8
10-09-2010, 02:59 PM #1
Anyone have a list of torque specifications for a 1983 240D?
Chilton manual has very little detail on anything and my MB service manual does not have a complete listing.
I’m looking for the following torques:
Starter bolts
Rear axle shaft to caliper retaining bolt
Engine mount to engine
Rubber engine mount bolts to frame
Drive shaft to rear end
Drive shaft to transmission
rear end to subframe
Thanks
1966 Chevelle 427BB
1980 VW Diesel Pickup
1983 240D 3.0 TD 4spd
2002 Dodge Quad 4x4 CTD
Patrick
Starter bolts
Thanks
1966 Chevelle 427BB
10-13-2010, 08:41 PM #2
(10-09-2010, 02:59 PM)Patrick Anyone have a list of torque specifications for a 1983 240D?
Starter bolts
Thanks
1. Very good and very tight
2. If you mean the 13mm that goes into the axle, not to tight and not too loose.
3. Not too tight. Aluminum
4. Not too tight. pretty small.
5. Good and tight, use loctite
6. Ditto
7. Not too tight, strips easily enough, loctite
Like those numbers? Big Grin
Starter bolts
Thanks
6. Ditto
300D50
Graphite Moderator, ala RBMK
10-14-2010, 03:32 AM #3
I usually use about 10 to 200 gruntpounds on the breaker bar, depending on phase of moon, water table levels, and if brazilian cocoa is high in the market.
To be honest, as long as you don't overdo it you should be good.
300D50
George3soccer
10-14-2010, 03:51 PM #4
Judge by type of material, and what size bolt or nut it actually is.
George3soccer
