STD Tuning Engine Holset HX55 4036892 for Cummins ISX 450
TURBOGUY
10-02-2010, 02:02 PM #1
I would like to get a used turbo Holset HX55 4036892 for Cummins ISX450. Can some one help? Thanks.
TURBOGUY
gen3performance
I like the smell of No. 2......
89
10-02-2010, 07:03 PM #2
I got a Hypermax HX-50 off of our International 466 hot farm pulling tractor. We dynoed 800+ hp with it if you wanted to crank your ISX up! Just throwin it out there...
1981 300SD...Too much propane = bent rods. Junked
1980 240D...Body fell off. Saved drivetrain and junked
1985 300D...No.2 and N2O = 16.35@85mph. Sold Sad
1999 E300TD...3" exhaust with banks muffler, Hx-35, 215hp tune, IP resistor box, bad crankshaft snout Angry
2005 E320 CDI...AMG injectors, EGR removed, mapping
Vids! http://www.youtube.com/user/silverado408
Pics! http://s776.photobucket.com/albums/yy42/...rformance/
gen3performance
BRABUS
10-02-2010, 07:16 PM #3
I got a hx52(hx50 exhaust/hx55 turbine) and a hx60 Smile if you are interested
This post was last modified: 10-02-2010, 07:17 PM by BRABUS.
BRABUS
10-02-2010, 10:54 PM #4
You should have asked last year, I sold it on eBay for $150.
Holset HX55 (4036892)
Cummins ISX Signature 450
Compressor
Exducer: 98mm
Inducer: 69.35mm
50 trim
14 blades
Turbine
Inducer: 85.8mm
Exducer: 79.6mm
12 blades
[Image: attachment.php?aid=1102]
Compressor
Exducer: 98mm
Inducer: 69.35mm
50 trim
14 blades
Turbine
Inducer: 85.8mm
Exducer: 79.6mm
12 blades
gen3performance
89
10-06-2010, 01:38 PM #5
For anyone ever looking for a used turbo I can recommend a place called R&S Distributing in Minooka, Illinois. They reman pretty much every turbocharger as far as I know. I went there once to check it out because a friend and I were going to build a jet engine from a turbocharger. I wanted to buy the turbo that stood waist high but settled for a smaller garrett from an army tank.
Anywho...I always ask for Rich and ask him for a good used core of what you're looking for. Many of the used turbos that are there at R&S are perfectly fine but end up there from engine rebuilders who reman engines.
gen3performance
TURBOGUY
10-11-2010, 02:29 PM #6
Thanks guys for all the information. Will keep searching...
TURBOGUY
