STD Tuning Engine New and ready to learn
tooels
Still Rolling
5
10-11-2010, 12:11 PM #1
BLUF- what did Mercedes do differently between 1980 and 1981 to increase the horsepower on the 300SD from 110 to 125 without changing the geometry of the engine? What can be done to get the performance increase to the older engine?
Hi. I'm an officer in the US Army and recently aquired a 1979 300SD with 160k original. It's been parked in a pasture so it needs some tlc to the interior and paint but it starts up and runs probably as well as the day that it was parked.
I know a little diesel theory but have never owned one before. I'm trying to read as much as I can on the car. My guess is that between the OM617.5 and the OM617.51, Mercedes let the engine drink deeper. Is that true? I look forward to responses.
tooels
10-11-2010, 12:24 PM #2
They increased lift and duration of the valve timing with a different cam.
This post was last modified: 10-11-2010, 12:25 PM by ForcedInduction.
tooels
Still Rolling
5
10-11-2010, 12:31 PM #3
(10-11-2010, 12:24 PM)ForcedInduction They increased lift and duration of the valve timing with a different cam.
So? Is a cam swap just a simple swap or did they change the head too? What if anything can be done to the fuel system and to the induction to gain more power?
tooels
10-11-2010, 12:33 PM #4
Cam, valve springs and follower fingers. You'll also need to increase the injection quantity to get any more power.
The flip side of the coin is that you could also just turn up the fuel for more power and increase boost further than normal to compensate for the reduced airflow (far far easier and free)
This post was last modified: 10-11-2010, 12:34 PM by ForcedInduction.
tooels
Still Rolling
5
10-11-2010, 12:43 PM #5
(10-11-2010, 12:33 PM)ForcedInduction The flip side of the coin is that you could also just turn up the fuel for more power and increase boost further than normal to compensate for the reduced airflow (far far easier and free)
Thanks. That option seems far more appealing. Are there any existing threads or archives on the subject that you could direct me towards?
tooels
George3soccer
10-11-2010, 05:05 PM #6
Right at the top at the important Threads.
http://www.superturbodiesel.com/std/ip-f...t-189.html
George3soccer
tooels
Still Rolling
5
10-11-2010, 09:01 PM #7
(10-11-2010, 05:05 PM)George3soccer Right at the top at the important Threads.
Thanks. What about a thread for increasing the boost pressure on the turbo? I realize that may be a simple answer that doesn't require it's own thread and if so please correct my ignorance.
tooels
10-11-2010, 09:06 PM #8
boost adjustment
http://www.superturbodiesel.com/std/cw-o...-1754.html
there is a 'tang' holding the cover on the wastegate. It's like a coil or two from a slinky jammed in to hold the cover on. I made another adjustment to mine today.
boost adjustment
tooels
Still Rolling
5
10-11-2010, 09:52 PM #9
thanks to everybody for all the insights. i'll keep you posted as things progress
tooels
