STD Maintenance General 617 glow plug light and cold starts
300GD
10-13-2010, 07:36 PM #1
Hi,
My glow plug on 1987' 617.931 non turbo motor does not come on all time.Bulb is ok but never come on when i start motor will come on if i turn key half back turn in ignition but not when starting engine .I know glowing works becouse engine starts if i hold on warm for couple sec and i see voltage drop. Is this normal ? how can i tel if all 5 glow plugs are working properly?
I hearded about some sensor in block reading temp.Last night was very cold and i had some starting issue. I can i veryfiy if engine is geting enugh heat from plugs ? how long should i keep them on before cranking motor? appreciate any help J
300GD
Hi,
10-13-2010, 08:33 PM #2
Check dieselgiant.com for DIY GP check.
300GD
10-13-2010, 09:44 PM #3
Thank you .I read up on this one .Just was also hoping for answer if glowplug light should be on everytime i turn key on.
300GD
10-14-2010, 06:55 AM #4
When its cool or cold outside it should be on everytime. Only in 85+? should it not.
300GD
10-14-2010, 05:20 PM #5
Thank you Winmutt. After all this info i know i have problem with foulty glow plugs. Will replace them all .
thanks again J
300GD
thanks again J
