Running on gasoline/paraffin/diesel mix?
I read somewhere that parafin as no lubricacity and if your pump is "oiled" with the fuel you will be in trouble. Might seize up...
In another hand, in Mauritius there is a guy that swear that by putting some in your tank and drive like you stole it it'll clean the engine. Lots of smoke and spatter. But I'll be a wee worry there...
I haven't tried paraffin but I did convert my truck from gas to diesel.
I had a little bit of gasoline residue in my tank when I filled it up with diesel and my engine ran like crap for that first tank.
So from that, I assume it doesn't take much gasoline to make the engine run terrible.
I remember seeing something in the manual about the acceptable percentage of kerosene you could mix in, but afaik gasoline causes some nasty pre-ignition.
(10-09-2010, 02:47 AM)erling66 Are there some fact behind this statement, or just your opinion? better to be safe than to try something new.
(10-09-2010, 08:11 AM)ForcedInduction(10-09-2010, 02:47 AM)erling66 Are there some fact behind this statement, or just your opinion? better to be safe than to try something new.
If you knew what all that crap does to engines you would understand how ridiculous that question is.
(10-09-2010, 03:09 AM)300D50 I remember seeing something in the manual about the acceptable percentage of kerosene you could mix in, but afaik gasoline causes some nasty pre-ignition.
G@soline explodes too fast for diesels and it strips lubrication off all the injection surfaces.
(10-11-2010, 02:33 PM)ForcedInduction G@soline explodes too fast for diesels and it strips lubrication off all the injection surfaces.
Just make some, all ya neet is methanol, lye, and a few drums. :p
I'm of the type that doesn't like feeding my engine things it wasn't designed to run with, but heh, your engine only lives once(maybe more if it's rebuildable)
(10-11-2010, 08:38 PM)300D50 Just make some, all ya neet is methanol, lye, and a few drums. :p
Kero acts as an anti-gell agent, and iirc winter mix has a small bit of it added anyways. You can run an engine on it, you just have a slight reduction in overall power because of the lesser energy density of kerosene.
Additional lubrication is required for any significant percentage of kero in the tank.
There is no need to add anything to winterized diesel unless you're transporting it multiple states north into a much colder climate.
Ah, yes. I forgot about needing additional lubrication with the kero.
(10-12-2010, 08:11 AM)ForcedInduction There is no need to add anything to winterized diesel unless you're transporting it multiple states north into a much colder climate.
(10-13-2010, 03:18 AM)Silberpfeil What temp have you guys been down to in a w123.-22*f
Quote:So... obviously I'm thinking ?? a radiator 'skirt' is in order???A new thermostat. The engine shouldn't have trouble staying warm even when its very cold. If its had and holes drilled it will never maintain temperature.
(10-16-2010, 03:18 AM)Olivier Why was it a bad habit?
I found some facts about gasoline mix in diesel fuel.
Gasoline will wash away lubrication in the injection system but that can be solved by adding some 2 stroke oil.
Gasoline will lower the cetane number(the fuels ability to self ignite). This will lead to more difficult cold start, but more important, the ignition delay will be longer and when it ignite, there will be more fuel in the combustion chamber giving a less controlled higher pressure(sounds like knocking).
The combustion temperature will be higher and that can cause serious problems for the nozzles. melt down or clogging of the tip and also carbon buildup internally that will wear down the nozzle.
So my conclusion is to avoid gasoline mix in the diesel fuel. Some people claim that it can help to clean up the head and piston from carbon buildup(because the higher temperature) but probably it won`t.
If you accidentally fill some gasoline in your diesel car and have mechanical IP, you will most likely be OK if you are able to lower the gasoline percentage below 20%. But if you have a newer engine(common rail) you will have a serious problem. You should not run the engine at all, and need to drain the whole fuel system.
(10-13-2010, 07:57 AM)ForcedInduction [quote='Silberpfeil' pid='19020' dateline='1286957893']What temp have you guys been down to in a w123.-22*f
(10-16-2010, 05:31 AM)ForcedInduction On really sub-zero days (-15*f or colder) I cover the upper half of the radiator and pull it as soon as the weather breaks.
(10-23-2010, 01:17 AM)Silberpfeil What temp thermostat do you recommend?? Particular brand??Stock 80*c Behr.
Quote:What do you use to cover it?Cardboard or plastic bags. Airflow engine fan and vehicle movement will keep them there.
On my '85 Peugeot TD, I made a grill cover out of masonite, and cut two 4 inch diameter holes in it. It's held on by a brass bolt/wing nut washer combo. I keep it on all winter once the average daily temp goes below 0 c, and block the holes if I'm just driving around the city, or the ave daily temp goes below -10c. The motor comes to normal op temp much quicker, my mpg goes up and I get good heat in the cabin compared to not using a grill cover.
