STD Other Alt fuels New england winter VS. WVO: heated fuel lines
  • 1 Vote(s) - 5 Average
cannonballSDL
CONTROL_agent21
66
10-20-2010, 11:56 AM #1
Hey guys, im thinking of making coolant heated fuel line like this,
(http://www.instructables.com/id/heated-h...nversions/)
as it stands i have a fuel heater just before the filter that keeps my oil hot! Some times it will keep the tank at a stable temp, but im not sure that will happen quickly in the winter. in the last few winters my big problem has been fuel gelling in the lines, so maybe this will cure my problem!
my question is where do i get the 3.8 aluminium piping, and will the factory electric pump be able to coup with the extra 24+ feet of 5/8 coolant line?
Also if you have any tips of how to winterize please post them!
Thanks guys!
This post was last modified: 10-20-2010, 12:01 PM by cannonballSDL.
cannonballSDL
Thanks guys!
10-20-2010, 12:25 PM #2
(10-20-2010, 11:56 AM)cannonballSDL in the last few winters my big problem has been fuel gelling in the lines, so maybe this will cure my problem!
Using the correct fuel, diesel, will solve the problem permanently.
cannonballSDL
CONTROL_agent21
66
10-20-2010, 12:48 PM #3
[Image: 1183096220824.gif]
Well you wrong diesel gells -10 happens, but how about i swap the WVO for diesel and you post something worth while?
cannonballSDL
10-20-2010, 09:00 PM #4
making something like that out of copper pipe looks like an especially shitty short term solution, at least in that how to article. I mean, they want you to slip some rubber over the aluminum line, then hose clamp rubber hose over that to create a seal for the coolant not to pass? Are they serious? They actually want you to trust your engine cooling system integrity to a seal like that for the long term? those directions are written by a hack, thats a sloppy solution.
Same deal on sealing the rubber hose by just slipping it over the smooth cut off copper pipe.
Why don't you go with a compression fitting (also come in DOT certified) to get the aluminum tubing out of the cooling channel, and a threaded T with two hose barbs. that way you have no questionable connections like that, and much better connections all around.
All the VO companies using Hose in Hose setups have been doing it that way for a while too, there a lots of example pictures floating around. Heres a pic of the same connection I did on my escort diesel a few years back.
Note- I ended up using a 3/4 coolant hose, the barb in the pic is 5/8, and I had to drill out the pipe seating of the compressing fitting so the tubing would fit through, but even though its bulky, ugly and crude, it worked great and it was extremely heavy duty. Plus, it was all brass, and had less of the galvanic reaction problem that copper would have in a predominately aluminum cooling system.
EDIT- I just read through the comments on that article, and the author's reasoning about flow, and compression fitting not coming off. I had no problems with flow, and I did not WANT my compression fitting to come off. But that is a factor, once you tighten the compression fitting down, you do crimp it permanently for the most part around the tubing depending on the tubing thickness you use.
This post was last modified: 10-20-2010, 09:10 PM by JB3.
10-21-2010, 06:52 AM #5
(10-20-2010, 12:48 PM)cannonballSDL Well you wrong diesel gells -10 happens
That is false information.
If it were true, please explain why I have started and operated my car on multiple occasions without problems when the ambient temperature has been down to -20*f (No Diesel911, tank heater, hair dryer, ether, g@soline, etc).
This post was last modified: 10-21-2010, 06:55 AM by ForcedInduction.
cannonballSDL
CONTROL_agent21
66
10-21-2010, 11:32 PM #6
(10-20-2010, 09:00 PM)dropnosky Why don't you go with a compression fitting (also come in DOT certified) to get the aluminum tubing out of the cooling channel, and a threaded T with two hose barbs. that way you have no questionable connections like that, and much better connections all around.
Cool! i dident think of using that heafty stuff! Do you have any more pics of your set up?
(10-21-2010, 06:52 AM)ForcedInduction
Opps i was a degree or to off!
Dident rudolf diesel's motor run off peanut oil?
This post was last modified: 10-21-2010, 11:41 PM by cannonballSDL.
cannonballSDL
300D50
Graphite Moderator, ala RBMK
10-22-2010, 12:05 AM #7
Yes, but it didn't use a precision injection system that cries when fed old fryer oil.
To each their own.
300D50
To each their own.
Olivier
10-22-2010, 02:10 AM #8
Some run the line inside the cabin. Would that be an option for you?
Or larger diameter 10mm pipes, this might help as well.
Olivier
Olivier
Olivier
10-22-2010, 06:59 AM #9
(10-21-2010, 11:32 PM)cannonballSDL Dident rudolf diesel's motor run off peanut oil?
It ran off coal dust.
Even if it did run on peanut oil, the only relation between his engine and yours is they both use a piston and crankshaft.
cannonballSDL
CONTROL_agent21
66
10-22-2010, 08:50 AM #10
(10-22-2010, 12:05 AM)300D50 Yes, but it didn't use a precision injection system that cries when fed old fryer oil.
To each their own.
I guess my father's has been crying for years! if its really going to turn into a big deal ill just change the words around alittle and everyone will be happy!
(10-22-2010, 06:59 AM)ForcedInduction
Im 90% sure it runs off peanut oil, but my father that physically saw the motor says it ran off peanut oil.
This post was last modified: 10-22-2010, 08:53 AM by cannonballSDL.
cannonballSDL
To each their own.
10-22-2010, 09:34 AM #11
Theirs some good history on here! The early engines used compressed air to inject the fuel before TDC directly in to the cylinder
http://en.wikipedia.org/wiki/Diesel_engine#History
This post was last modified: 10-22-2010, 09:49 AM by willbhere4u.
10-23-2010, 07:15 AM #12
(10-22-2010, 08:50 AM)cannonballSDL Im 90% sure it runs off peanut oil, but my father that physically saw the motor says it ran off peanut oil.
Then you're 90% wrong. What your father saw was the first successful engine, his first engine didn't use liquid fuel.
This post was last modified: 10-23-2010, 07:16 AM by ForcedInduction.
10-23-2010, 08:55 AM #13
cannonball, there are lots of online sources for aluminum piping. type in aluminum fuel lines on google, and you can get some decent looking stuff. Also, you can buy it very specifically at Mcmaster-Carr and specify ID and OD, but its pricey. I think some of the VO-kit makers also sell hose in hose kits, you should check out their sites.
Unfortunately, I don't have any more pics of that setup on that escort, but it was pretty cool. It was an 86 2.0 diesel 5-speed escort, at 50 hp. Big Grin It got approximately the same fuel economy as a newer jetta diesel, around 45 mpg.
I threw a 30 gallon tank in the back, filling the whole trunk, and the sucker had a 1300 mile range. it was DANGEROUSLY slow though, ended up selling it to some shoeless hippies who ended up making the car look like shit in the way that only hippies can.
I think underneath, I bundled my coolant hose with some foam pipe insulation which worked pretty well removing wind chill. Oliver is right, some people end up running the lines inside the cabin, but this might be illegal technically from a DOT standpoint I believe. Better do some research on that first. Oliver, whats the rule in Scotland?
This post was last modified: 10-23-2010, 11:33 PM by ForcedInduction.
cannonballSDL
CONTROL_agent21
66
10-23-2010, 03:49 PM #14
(10-23-2010, 08:55 AM)dropnosky ] VO pissing contest on almost every VO related thread?
Thanks man!
i found a place local where i can get the piping and im going to start making it ASAP(i saw snow!). Next im going to heat the injector lines and filter, but im going to rig them to a remote starter so i can start heating the lines before i start the car.
Are the pad style heaters affective? i guess having the block heater and a pad heater on the tank on the same circuit would make scene.
I just want to cure the problems we have been having with running WVO in the cold.
cannonballSDL
Thanks man!
10-23-2010, 11:34 PM #15
(10-23-2010, 03:49 PM)cannonballSDL I just want to cure the problems we have been having with running WVO in the cold.
Another reason why BioDiesel was invented, it doesn't turn to jelly at 40*.
If you're truly serious about sticking with grease, invest in a webasto heater.
This post was last modified: 10-24-2010, 12:27 AM by ForcedInduction.
10-24-2010, 12:42 AM #16
(10-23-2010, 11:34 PM)ForcedInduction
Obviously he's serious about sticking with grease, Im not sure that was ever in question for him.
This post was last modified: 10-24-2010, 01:04 AM by ForcedInduction.
10-29-2010, 12:33 PM #17
I live in purty warm weather so i dont have to worry too much about the cold, or my fuel gelling.
But i would suggest looking into the following:
Make sure all your GP's are new and working.
Fuel line heaters, and a in-tank heater.
Flat plate heat exchanger.
How about putting a extra fuel tank in the trunk that will hold a few gallons of diesel that you start, and turn your car off on, and switch to VO after its all warmed up?
Have you thought about adding a gallon or so of diesel to a whole tank of VO to help thin it? Or an additive?
Is that an option?
Is that an option?
cannonballSDL
CONTROL_agent21
66
11-18-2010, 05:44 PM #18
Up date: its been super warm and i have been running WVOSmile maybe i should start getting ready for winter before winter comes!
cannonballSDL
 16 Guest(s)
 16 Guest(s)
