STD Tuning Drivetrain Red Line MTL
Red Line MTL
Red Line MTL
11-03-2010, 01:41 PM #1
Which one to use? This is for 5spd for w124.
jeemu
457
11-03-2010, 04:20 PM #2
(11-03-2010, 01:41 PM)winmutt Which one to use? This is for 5spd for w124.
I used Redline D4 atf, but high rpm gears dont go in wery good.
So i test MTL and gears go much better in.
This is now in the tranny http://www.redlineoil.com/product.aspx?pid=45&pcid=7
This post was last modified: 11-03-2010, 04:23 PM by jeemu.
jeemu
11-03-2010, 05:23 PM #3
MTL is not good for MB's manuals, it will make shifting worse if it has any wear.
It needs to be ATF based, D4 or Mobil1.
[Image: 51.png]
This post was last modified: 11-03-2010, 05:24 PM by ForcedInduction.
[Image: 51.png]
jeemu
457
11-03-2010, 05:34 PM #4
(11-03-2010, 05:23 PM)ForcedInduction MTL is not good for MB's manuals, it will make shifting worse if it has any wear.
[Image: 51.png]
Hmm. Yes Mb manuals use atf oil, but Redline MTL is suitable on those trannys and gears go better in.
jeemu
[Image: 51.png]
11-04-2010, 06:24 AM #5
(11-03-2010, 05:34 PM)jeemu Redline MTL is suitable on those trannys and gears go better in.
Possibly in newly rebuilt ones. If its worn to where it ever grinds going into a gear (without being forced) MTL will make it grind more often.
MTL made my old slope-back tranny shift a lot worse compared to dino ATF. The rebuilt flat-back tranny has had Mobil1 ATF from day 1 and it shifts perfect.
jeemu
457
11-04-2010, 06:58 AM #6
I have old 717 433 and it is better with mtl, also getrag s is better shifting.
D4atf is better cold weather because it s not that stiff.
jeemu
11-04-2010, 09:24 AM #7
I got the MTL. The manuals specify ATF with Suffix A, However I cant find any of these around...
Aral SGF 84
BP Autran GM-MP
Castrol TQ
Esso ATF Type Suffix A
Mobil ATF 200
Shell Donax TM
Texaco Texamatic 1585
Aral SGF 84
BP Autran GM-MP
Castrol TQ
Mobil ATF 200
Shell Donax TM
01-25-2011, 10:03 AM #8
So the MTL is great when warm. When I first shift into first and second its too stiff. Not sure if I am going to take the time to swap it out now, I will probably wait till Fall. Forced I was unable to find the ATF. In my 4 spd I currently have Royal purple which works well. I think I will probably spend the change and get the OE stuff.
 6 Guest(s)
 6 Guest(s)
