STD Other Projects '74 L508D Motoroam Monarch OM314
01-06-2009, 11:06 PM #1
work in progress :
http://www.superturbodiesel.com/images/b...0motoroam/
This post was last modified: 02-04-2009, 03:14 PM by winmutt.
01-07-2009, 04:50 AM #2
Wow! Looks like you've got quite the project to dive into! I've seen a 352 before, but tats the first 314 I've seen. Direct injection though, nice score.
How are you going to get it back home?
01-07-2009, 01:32 PM #3
Drive it. Plan is now to drive down with 2 buddies on a fri night and spend weekend trying to get it road ready.
oel_brenner
01-10-2009, 11:30 PM #4
dude.. thats effin sweet !!!!
NEVER seen one of those...
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
cars
trucks
boats
01-11-2009, 05:29 AM #5
Have you seen this site? http://www.jefflondon.net/
01-12-2009, 02:08 PM #6
Ya I talked to this guy a bit on the phone when I first one it. Nice enough guy. There is a local to me unimog place that has all kinds of stuff that I may need.
The future?
[Image: om314.turbo.jpg]
The future?
01-30-2009, 09:15 AM #7
This is a L508D not an O309D (same chassis different uses).
This is the weekend to see it!
bgkast
VGT-Intercooled
325
01-30-2009, 07:57 PM #8
There is one of those turbo OM 314s for sale here in Portland if you want me to look at it for you.
bgkast
02-02-2009, 10:01 AM #9
Video of it cranking!
http://superturbodiesel.com/images/benz/...vstart.mov
Pics to come.
Pics to come.
02-02-2009, 10:06 AM #10
Spray some ether into it! Big Grin
02-02-2009, 10:14 AM #11
I was Sad, it is sucking in air somewhere as the return line had air constantly coming out. Lift pump? Primer pump?
02-02-2009, 11:28 AM #12
Probably a rotted fuel line.
02-02-2009, 11:56 AM #13
There was a rubber line between the engine and the hard line going to the tanks. I spliced in here and ran it off a 5 gal tank of diesel. You know there was a fuel line coming off the back of the head that went to a T right where the rubber line split off. This hose was rotted and one I didn't run into the can. I'll have to read the FSM.
Shawn112270
04-22-2009, 02:32 PM #14
(01-06-2009, 11:06 PM)winmutt work in progress :
I have a 1986 Motoroam with an OM352 motor, etc. My question is where did you find the data plate that is in German? I have crawled around this RV and nothing so far.
Thanks,
S
Shawn112270
Thanks,
S
04-22-2009, 05:22 PM #15
Talk to these guys : http://www.eurotruck-importers.com/
Excellent resource. Got pics? Put up a profile, I'd love to see it. 352 is tasty, turboed?
04-27-2009, 08:51 AM #16
[Image: DC30940411091929.jpg]
This post was last modified: 04-27-2009, 08:52 AM by winmutt.
04-27-2009, 08:54 AM #17
Brought it home!
Loaded:
[Image: 04-25-09_1858.jpg]
Unloaded:
[Image: 04-26-09_2030.jpg]
This post was last modified: 04-27-2009, 08:58 AM by winmutt.
Brought it home!
Loaded:
Unloaded:
05-31-2011, 10:20 AM #18
I finally found someone that was more deranged than I. I realized the full intensity of his derangement when he showed up with a f150 and a car trailer. I didnt have the heart to take a pic of the trailer buckled but needless to say the RV made it about 200ft downhill from my house in an empty lot.
[Image: nightmare.finds.a.new.home.jpg]
This post was last modified: 05-31-2011, 10:21 AM by winmutt.
05-31-2011, 10:48 AM #19
did you get it running?
Riverstick
08-18-2011, 02:37 AM #20
I worked on those 508D's 20 odd years ago.....Bombproof reliability in a nutshell....I've seen several cover 600,000kms without an issue....Very simple straight forward machine and the OM314 was a brilliant engine....They were very popular as 25 seater mini coaches around here....It should be a very simple project to get right mechanically..
Riverstick
08-18-2011, 07:20 AM #21
Never got it running, rebuilding the pump was $$$. The new owner has emailed me and said it has new subflooring and the pump was in the shop.
Riverstick
08-18-2011, 03:04 PM #22
I never ever saw an injector pump give trouble in one....what was wrong with it.........I remeber pulling OM314's & OM352's out of the bushes and getting them working with very little work....We used to run the OM352's to 800,000-1,000,000kms without any great problems...and after that we used to export them to Africa and the third world still running
Riverstick
 7 Guest(s)
 7 Guest(s)
