STD Tuning Engine New video on Drifting Wagon!
jonbobshinigin
10-19-2010, 02:56 PM #1
Check it out: http://www.youtube.com/watch?v=YlwTxw-02...re=related
1987 300TDT - 260,000 Miles
10-19-2010, 03:58 PM #2
Thats awesome, props to that dude for calling out the japanese and bimmers at the end of the video.
I cant wait to see what upgrades they will have for it next year.
Now we need an American team with a Merc diesel in it competing!
Olivier
10-19-2010, 04:11 PM #3
This is cool...
7mm element and the scania turbo. Woohoo!!! I want one Smile
Olivier
This is cool...
Oil Burner
Turbo Everyting!!!
83
10-19-2010, 06:23 PM #4
Got to love people that have sponsers and there extreme measure to be at the top Magor Cudos
Oil Burner
conski
11-18-2010, 12:15 PM #5
Pretty sick vid, his english is a bit broken though. Did anyone hear what kind of transmission he has in there? I couldn't understand him but it sounded like he said Tremec?
1990 300CE
Looking for a diesel project
conski
1990 300CE
11-18-2010, 01:18 PM #6
This post was last modified: 11-18-2010, 01:20 PM by willbhere4u.
ben2go
Diesel Dumby
129
11-18-2010, 01:19 PM #7
Tremec TKO 600
ben2go
Tremec TKO 600
conski
11-18-2010, 01:35 PM #8
Thanks man, what kind of modifications woudl need to be done to get that tranny bolted up to a om603?
1990 300CE
conski
1990 300CE
ben2go
Diesel Dumby
129
11-18-2010, 01:53 PM #9
You would need an adapter plate,pilot bearing,clutch,and flywheel plus machine work to make it all interact without fighting.IIRC, the input shaft on a TKO600 has 26 or 27 splines,so it's kind of a unique set up.
ben2go
conski
11-19-2010, 10:07 AM #10
(11-18-2010, 01:53 PM)ben2go You would need an adapter plate,pilot bearing,clutch,and flywheel plus machine work to make it all interact without fighting.IIRC, the input shaft on a TKO600 has 26 or 27 splines,so it's kind of a unique set up.
Thanks for the info dude!
What do you think would be the easiest and most cost effective manual transmission swap to an om603 that could handle 450hp max?
1990 300CE
conski
1990 300CE
Mylesofsmyles
Volvo Tweaker
76
11-19-2010, 04:53 PM #11
those kids r tight! i love black smoke racing...my inspiration for wanting a w123 300td
"home made intercooler and it's, quite...BIG!"
Mylesofsmyles
ben2go
Diesel Dumby
129
11-20-2010, 07:30 PM #12
(11-19-2010, 10:07 AM)conski
You can up grade T5 or TKO to handle that kind of torque.
ben2go
conski
11-21-2010, 02:11 AM #13
(11-20-2010, 07:30 PM)ben2go
Would a T5 be easier to adapt to the om603? They are a lot more abundant and significantly cheaper as well. I figure if they can stand up to a v8's power then they should do fine with what I want, with a heavier clutch though for sure.
1990 300CE
conski
1990 300CE
ben2go
Diesel Dumby
129
11-21-2010, 12:33 PM #14
Here is some history on the T5 and what they came in.Scroll down and there's a list with specs.You'll need the highest torque rating you can find,but it still won't be enough for 400+hp without building the transmission.Diesels put out way more torque than a g@$$er.
http://www.allfordmustangs.com/Detailed/349.shtml
Another version of what's above without the chart.
http://www.moderndriveline.com/Technical...istory.htm
This post was last modified: 11-21-2010, 12:33 PM by ben2go.
ben2go
conski
11-21-2010, 12:58 PM #15
(11-21-2010, 12:33 PM)ben2go Here is some history on the T5 and what they came in.Scroll down and there's a list with specs.You'll need the highest torque rating you can find,but it still won't be enough for 400+hp without building the transmission.Diesels put out way more torque than a g@$$er.
Okay, thanks for the info. Really appreciate it.
1990 300CE
conski
1990 300CE
ben2go
Diesel Dumby
129
11-21-2010, 03:27 PM #16
You're welcome.
ben2go
You're welcome.
