STD Tuning Suspension Coilovers
Coilovers
Coilovers
09-13-2009, 04:37 PM #1
Ive seen pics of a w123 wagon, and a w116 with coilover setups.
Is this a option on some models... that could be swapped over?
Or a fully custom job?
SurfRodder
Jackass Extraordinaire
611
09-13-2009, 07:17 PM #2
(09-13-2009, 04:37 PM)garage Ive seen pics of a w123 wagon, and a w116 with coilover setups.
where did you see this?
OBK# 62
SurfRodder
OBK# 62
09-13-2009, 08:45 PM #3
I cannot remember where i saw the wagon at, when i fing it ill post it.
As far as the 116
http://www.topklasse.net.au/forums/showt...php?t=1636
2nd and 3rd picture.
Locked diff too!
hehe
As far as the 116
Locked diff too!
hehe
09-13-2009, 09:29 PM #4
Those aren't coilovers, those are shocks inside the springs. The stock configuration.
This post was last modified: 09-13-2009, 09:29 PM by ForcedInduction.
09-14-2009, 05:40 AM #5
(09-13-2009, 08:45 PM)garage ...
OT- I dig the w116 wagon...
09-14-2009, 12:21 PM #6
(09-13-2009, 09:29 PM)ForcedInduction Those aren't coilovers, those are shocks inside the springs. The stock configuration.
If thats stock configuration, why isnt my 116 like that?
I have shocks besides the coil.
(09-14-2009, 05:40 AM)DeliveryValve
I know right, talk about rare.
This post was last modified: 09-14-2009, 12:22 PM by garage.
09-14-2009, 12:50 PM #7
(09-14-2009, 12:21 PM)garage If thats stock configuration, why isnt my 116 like that?
On the front, yes.
On the front, yes.
09-14-2009, 03:05 PM #8
Geez, well im just talking nonsense then.
Your right.
Well has that been heard of at all on these cars(coilovers)??
Your right.
charmalu
09-18-2009, 09:26 PM #9
(09-13-2009, 08:45 PM)garage I cannot remember where i saw the wagon at, when i fing it ill post it.
As far as the 116
Locked diff too!
hehe
That 4th picture looks like the Aluminium trailing arms from a W126.
these were discussed over on Peachparts a while back. thought the
consenses was they wouldn`t fit.
Were they available for the w123 in other markets?
Charlie
charmalu
As far as the 116
Locked diff too!
hehe
Charlie
09-19-2009, 06:52 AM #10
This is a 116.
This is a 116.
CID Vicious
10-04-2009, 11:49 PM #11
Actually, if someone were willing to do the research, I'm pretty sure one could cobble together a coilover system for these cars using coilovers designed for other applications. It would be a matter of getting the right spring length figured out and mounting it. As far as shock settings and spring rates go you have your pick. I had a cheap set of Korean K-sport coilovers on my SE-R and it was a phenomenal difference in a car that had very good essentials from the factory already. Although the K-sports had pillow ball mounts, built in camber plates and came with Heim jointed endlinks for the rear sway bar, too.
I think that if someone were willing to do the homework, this is quite feasible for our cars and would certainly be a step up from cutting springs and whatnot.
CID Vicious
tantank79
T3-45
109
02-17-2010, 05:30 PM #12
What are people's thoughts on using the existing shock mounts as coilover mounting points?
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
Secondaries
02-17-2010, 11:03 PM #13
(02-17-2010, 05:30 PM)tantank79 What are people's thoughts on using the existing shock mounts as coilover mounting points?
Generally not a good idea. Shock mounting points were meant to be used only for damping, not for load bearing. The A-arms and trailing arms were probably designed to have the spring mounted in its cup only. There are other ways to get coil over adjustability, though...
Secondaries
tantank79
T3-45
109
02-18-2010, 09:16 AM #14
(02-17-2010, 11:03 PM)Secondaries There are other ways to get coil over adjustability, though...
Like...?
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
Like...?
-Brian
1983 300TD
1982 240D
1981 280TE
CID Vicious
02-18-2010, 10:55 AM #15
Look up some GM G bodies and the like with coilovers, while the systems are far from identical it's still upper and lower A's and the adaptation process would be similar.
That would be something to look into...adapting a QA1 coilover kit from another application.
CID Vicious
Secondaries
02-19-2010, 02:00 AM #16
(02-18-2010, 09:16 AM)tantank79
Like...?
Building an adaptor that fits into the spring cup, and accepts universal coilover sleeves, is pretty simple. 2 5/8" coilover springs are cheap and plentiful. www.stockcarproducts.com and Summit both have everything you'd need as far as the coilover parts.
Secondaries
Like...?
tantank79
T3-45
109
02-19-2010, 12:34 PM #17
(02-19-2010, 02:00 AM)Secondaries
Like...?
Ok, that is basically what I have been thinking about as well, but wanted to hear your ideas. I'm considering making adapters/towers that bolt into holes where the spring cups are originally bolted into the lower control arm and drilling a few holes in the upper spring seat area of the body.
This post was last modified: 02-19-2010, 12:35 PM by tantank79.
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
Like...?
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
T3-45
109
02-25-2010, 11:32 PM #18
What about on a wagon? The SLS shock mounting points were designed for load bearing.
(02-17-2010, 11:03 PM)Secondaries Generally not a good idea. Shock mounting points were meant to be used only for damping, not for load bearing.
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
mike-81-240d
more like mike-84-300d now
427
11-14-2010, 01:20 PM #19
The wagon that has coilovers is the team black smoke racing 300TD. It has RX-8 coilovers installed.
mike-81-240d
tantank79
T3-45
109
11-15-2010, 05:46 PM #20
Since this came back up, I would like to pose this question again.
(02-25-2010, 11:32 PM)tantank79 What about on a wagon? The SLS shock mounting points were designed for load bearing.
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
11-15-2010, 06:17 PM #21
The wagon chassis is very different from the sedan B-pillar back. The SLS supports the majority of the body load while the springs are basically there as a fail-safe.
SLS is available in the sedans. I don't know what, if any, reinforcement was done for them.
Einar
11-23-2010, 02:40 PM #22
What aout the W201.034/036, some of them had SLS all the way and springs similar to small motorcykles.
Einar
George3soccer
11-29-2010, 12:48 PM #23
sls 4 way on a w201 was only available in the euro 2.5-16v, and evo models. But thats only a option, and a dime a dozen. So goodluck with finding that.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
11-29-2010, 09:02 PM #24
(11-14-2010, 01:20 PM)mike-81-240d The wagon that has coilovers is the team black smoke racing 300TD. It has RX-8 coilovers installed.
Yeah but the suspension is no longer original either, i belive most of it is from a Toyota Aristo.
11-29-2010, 09:19 PM #25
The steering gear is from a volvo!
11-29-2010, 11:20 PM #26
The car is just bitchin
fha772
02-09-2011, 04:34 AM #27
(11-29-2010, 09:02 PM)garage
Yes, you are right, the team black smoke racing car has Toyota, gearbox, rearend, and some of the front suspension too(including steering rack).
PPC mag(uk), have just done an article on it, in the latest issue, I was actually quite dissapointed in how little of the original Mercedes was left.
In my sedan build, I'm trying to use as many Mercedes parts as possible, mainly just to challenge myself, but also because I think there is plenty of strong parts across the entire model range to build my car. But I am looking into fitting/making coilovers for my car.
I'll let you know how I get onWink
fha772
 10 Guest(s)
 10 Guest(s)
