STD Other Open 12 volt power sources
led-panzer
12-03-2010, 07:00 PM #1
When I finish my project I will have at least six things that require a 12 volt power source, three under the hood and three in the car. As far as in the car, would you use the wires for the cigarette lighter? And could three gauges run off of one set of wires? And for under the hood, is there an easy place to tap into? Obviously you don't wrap wires around the battery terminals (like the idiot who owned my jeep before meDodgy)
1985 300D 280,000 miles RIP
led-panzer
12-03-2010, 07:24 PM #2
You can use the cig lighter, especially if your putting your gauges there. The real question is how much amperage and how clean does it have to be? Auto DC is not clean.
12-04-2010, 06:55 AM #3
Run a wire down to the starter terminal and use an inline fuse.
You can also buy a fuse panel and mount it wherever you can find space. I got rid of the annoying glovebox light and mounted my panel in there.
led-panzer
12-04-2010, 01:29 PM #4
Do you use an inline filter for your EMP gauge?
led-panzer
12-04-2010, 06:21 PM #5
Nope.
Nope.
12-04-2010, 09:05 PM #6
inline filter for what?
led-panzer
12-04-2010, 09:34 PM #7
Exhaust manifold pressure gauge, I wondered if it would be needed to not clog the gauge with soot.
led-panzer
12-04-2010, 09:51 PM #8
I think it would be fine there is not a lot of air moving through it it just gets pressurized
I think the more important part is to use enough line so it dose not get hot! some people use copper line coiled around to cool it down form a 1000* +
12-04-2010, 09:52 PM #9
Ahhh gotcha. I didn't think about that!
12-06-2010, 02:01 AM #10
You could also wrap it around the ATF dipstick tube, that would work like a heatsink allowing less tube to be used.
This post was last modified: 12-06-2010, 02:03 AM by ForcedInduction.
led-panzer
12-06-2010, 07:41 AM #11
Thanks forced. Did you hook up your intercooler pump to that same fuse block?
led-panzer
12-06-2010, 08:25 AM #12
No. The pump must be cycled with the ignition. Its 1amp pull will drain a battery overnight.
This post was last modified: 12-06-2010, 08:25 AM by ForcedInduction.
led-panzer
12-06-2010, 09:35 AM #13
What if I wire it to a toggle? Sorry I know hardly anything about electronics, I'm a machinist not a mechanic Big Grin
led-panzer
12-06-2010, 09:46 AM #14
My pump toggles with the key in stock form... dunno if that's how it was ment to work or not but that's what happens
led-panzer
12-06-2010, 10:36 AM #15
I think ill toggle the pumps, that way when I start it the only draw on the battery will be the glow plugs, I'm paranoid about cold starts. Obviously the lights in the gauges get toggled to the headlight switch.
led-panzer
12-06-2010, 06:36 PM #16
An automatic-on option would be to use an oil pressure switch.
led-panzer
12-06-2010, 06:44 PM #17
But wouldn't a custom engraved plate with switches with the fancy covers look so much cooler? Big Grin
led-panzer
12-06-2010, 07:07 PM #18
Meh. I don't really like switches for very minor things cluttering up the dash when it could be done seamlessly with the ignition. If I need the pump off I just pull the fuse.
The only switches I have are for the rear dome light, turbo disable and water injection disable (dome, air compressor, WI and climate control knobs on the 240).
led-panzer
12-06-2010, 07:17 PM #19
The oil pressure switch was a very good idea though, I didn't think of that.
led-panzer
12-06-2010, 08:01 PM #20
Turbo disable what's that for super slow mode engaged!
12-06-2010, 09:39 PM #21
Prevents turbo surge at low speeds.
12-06-2010, 10:30 PM #22
Totally off topic but could a blow off valve be used to take care of the surge?
led-panzer
12-06-2010, 10:58 PM #23
How does a blow off valve work? Like a wastegate for the intake manifold?
led-panzer
12-06-2010, 11:24 PM #24
(12-06-2010, 10:30 PM)Captain America Totally off topic
HA! When was the last post relating to the thread topic? (#3)
Quote:but could a blow off valve be used to take care of the surge?
No. That would cause high exhaust pressure and easily overspeed the turbo.
This post was last modified: 12-06-2010, 11:25 PM by ForcedInduction.
12-06-2010, 11:31 PM #25
over speed it then slam the blow off valve closed and instant boost! 0-20 psi in .1 of a second hell yea!
12-06-2010, 11:42 PM #26
As well as a shaft in 20 pieces.
12-06-2010, 11:57 PM #27
I have an exhaust turbine out of a turbo eclipse
The shaft broke and I found it in the catalytic converter at the junk yard I work at! The funny part is that the turbo on the car was fine it had a rod knock but ran and made boost still! And there was another good turbo in the trunk!
They where using nitrous to spool the turbo or some junk like that it had a nitrous ports in the exhaust housing some really goofy stuff!
12-07-2010, 12:24 AM #28
I like willbe's thinking! BOV closes and POP goes the weasel bahahaha!
Well crap. Guess I didn't spend too much time thinkin that one out haha. Oh well, good thing it was just two cents and not dollors huh?
I know a guy that drag raced VWs. He was using a V8 distributor and the extra four wires went to four plugs that were in the turbine housing! Guess it worked real well in helping the huge turbo to spool
This post was last modified: 12-07-2010, 12:33 AM by Captain America.
12-07-2010, 01:07 AM #29
(12-07-2010, 12:24 AM)Captain America I know a guy that drag raced VWs. He was using a V8 distributor and the extra four wires went to four plugs that were in the turbine housing! Guess it worked real well in helping the huge turbo to spool
Thats not a bad idea at all. Kid of like the anti-lag rally racers use.
300D50
Graphite Moderator, ala RBMK
12-07-2010, 09:57 AM #30
Oooh, that's an interesting idea.... but how would you do it without screwing up the flow in the housing? I'm thinking you'd need custom electrodes.
And why the avatar change back to #21?
300D50
12-07-2010, 10:35 AM #31
Didn't like the picture and RD hasn't posted for 4 days.
12-07-2010, 12:23 PM #32
Hey forced how about this factory Mercedes blow off valve LOL!
http://cgi.ebay.com/ebaymotors/GARRETT-T...ccessories
led-panzer
12-07-2010, 03:30 PM #33
That is fail thread material lol
led-panzer
300D50
12-07-2010, 03:38 PM #34
bwaaaahahahahahhahahahhahahahhahahahahahahhahahhahahah!
Quote:
Dear jimmy1000000,
Hey, just wanted to let you know that isn't a BOV, it's the EGR valve off of a California car.
Hope that helps you out!
- waltz529
This post was last modified: 12-07-2010, 03:41 PM by 300D50.
300D50
Quote:
Dear jimmy1000000,
- waltz529
 17 Guest(s)
 17 Guest(s)
