STD Other Open free fuel?
free fuel?
free fuel?
12-15-2010, 05:50 PM #1
So, I like to buy a few dollars of fuel and check my oil pretty often. I have a cup of change in the car and save quarters for meters. I use the other change to help prepay for a bit of fuel. And nearly every pump goes over the amount that I have paid. Strange, I wonder why they stop like 10-30 cents past the amount I paid. Gas pumps always stop right on.
Seems like if I keep it up I will be making big savings since I just drive off and don't worry about the bit of fuel I stole.
Any insight on this phenomenon?
300D50
Graphite Moderator, ala RBMK
12-15-2010, 09:03 PM #2
Erm, watch your next tank be full of water and bugs from the gods of karma?
I've got mixed feelings on this one...
300D50
98taco3
12-16-2010, 05:56 AM #3
Seems the pumps just arent calibrated correctly. I wouldnt be surprised if its the other way around. Couple years back we had a gas station chain caught messing with the pumps. Said it was selling you more fuel than it actually pumped into the tank.
98taco3
12-16-2010, 08:49 AM #4
Legally, pumps have to flow the paid volume or higher. Big fines if they are found short pumping so stations calibrate the meters slightly high to make up for temperature density, flow bypassing the meter vanes, etc. Thats why people suggest fueling in the morning to get more dense fuel, even though underground tanks stay at a consistent temperature all day.
This post was last modified: 12-16-2010, 08:50 AM by ForcedInduction.
12-16-2010, 09:29 AM #5
maybe it's a small % of large fuel purchases to go over a few cents but, if I get like 30 cents a day that's good for me.
Today the lady may have gotten wise. I ordered 2.24 of fuel and it pumped superduper slow and then stopped at 2.23.
12-16-2010, 09:40 AM #6
Its also worth noting the flow meters are rated for accuracy at a certain minimum flow rate. So pumping super slow like that pretty much guarantees you get extra fuel since some of the pressure will seep past the gears/vanes.
