STD Tuning Engine OM617A superturbodiesel
Diesel-Wiking
12-22-2010, 04:30 PM #1
Hello.
is the manifoil and inlet good enough to handle 300-400hp? Or is it a must to customize? I mean the flow..
or is it better to choose 603 for such an project, is the flow better in this engine?
I will fit it in an old 69' BMW e9 race car.
(12-22-2010, 04:30 PM)Diesel-Wiking Hello.
is the manifoil and inlet good enough to handle 300-400hp? Or is it a must to customize? I mean the flow in the top lock(?) or what it's calledTongue
This post was last modified: 12-22-2010, 04:32 PM by Diesel-Wiking.
*1984 Mercedes S123 300TD turbodiesel*
*1993 BMW 525tdsT*
*1990 BMW 524 turbodiesel*
*1983 BMW 745iA e23*
*1969 BMW 3.0csl racecar*
Diesel-Wiking
Hello.
*1993 BMW 525tdsT*
George3soccer
12-22-2010, 05:02 PM #2
603 will make that power much more efficiently then the 617, and much easier.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
BRABUS
12-22-2010, 05:04 PM #3
The exhaust manifold wil "work", but a custom manifold will give you lower exhaust temp and earlier spool up.
The inlet manifold is okay, but with adding 3-5 inces on the runners and a new plenum it is as good as it can be for a om617 head!
Remeber for pushing more than 300-330hp of it, you need to go heavy on the head. A friend of mine in sweden got 400 hp in the engine with a HEAVY modified head, custom grinded cam, double valve springs and ported inn and outlets to the max.
(12-22-2010, 05:02 PM)George3soccer 603 will make that power much more efficiently then the 617, and much easier.
Yez. 603 and 606 will hit that numbers easy. But i like the charm of the om617, so i hope i choose the good old om617Smile
This post was last modified: 12-22-2010, 05:05 PM by BRABUS.
BRABUS
Diesel-Wiking
12-22-2010, 05:25 PM #4
what is the biggest problem to hit this numbers with the old 617? yes brabus, that's one of the reasons I want to use 617, and the sound is in my opinion much better too.
*1993 BMW 525tdsT*
Diesel-Wiking
*1993 BMW 525tdsT*
12-22-2010, 08:38 PM #5
A 617 will take a LOT of work to reach 300hp, a 603 will just need a turbo and injection pump.
ben2go
Diesel Dumby
129
12-22-2010, 09:52 PM #6
Here is the exhaust manifold thread about the best factory unit.
http://www.superturbodiesel.com/std/om-e...-1694.html
Here is the intake manifold thread about the best factory unit.
http://www.superturbodiesel.com/std/om61...t-445.html
Getting in good with a local wrecking yard will help with good parts cheap.
ben2go
Diesel-Wiking
12-23-2010, 08:21 AM #7
thank you for answer, but for a 603a, can you use those om606 manifoils(bolt on?)?
*1993 BMW 525tdsT*
Diesel-Wiking
*1993 BMW 525tdsT*
George3soccer
12-23-2010, 08:37 AM #8
I am not sure, but the 603 manifold is fine, just look for the 603 non turbo intake and build a plenum.
And for the exhaust manifold the euro 603 manifold will flow enough if not kkd makes a wicked exhaust manifold.
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
Einar
12-23-2010, 08:37 AM #9
No, the 606 is a 24V with "flat" ports against the manifolds, the 603 have another shape.
Einar
Diesel-Wiking
12-23-2010, 08:38 AM #10
(12-23-2010, 08:37 AM)George3soccer I am not sure, but the 603 manifold is fine, just look for the 603 non turbo intake and build a plenum.
awesome, thank youSmile
*1993 BMW 525tdsT*
Diesel-Wiking
*1993 BMW 525tdsT*
