STD Maintenance General How do I turn the engine?
led-panzer
12-31-2010, 07:09 PM #1
This may seem like a stupid question but I can't find an explanation. I want to pull the ip, This means turning the engine to TDC. I've read "on the crank balancer" which I'm sure is under the valve cover, I haven't pulled it yet. Could anyone specify for me or possibly post a pic of what I need to turn?
1985 300D 280,000 miles RIP
led-panzer
12-31-2010, 08:22 PM #2
oh I just read one way to find TDC. I guess you would need to use a clear tube so you could see when the cylinder is at its least volume
http://www.mail-archive.com/mercedes@oki...62885.html
led-panzer
12-31-2010, 10:09 PM #3
Thanks larsalan. Ok, I gathered that there are markings on the balancer to tell you where you are, whether that's where you truly are or not, my question was what nut or bolt do I turn that will rotate the engine?
led-panzer
12-31-2010, 10:20 PM #4
I turn the 22mm power steering nut that is attached to the crankshaft by a belt.
you'll be able to feel the compression strokes and with the valve cover off you can see the cam shaft turn too. dig it?
as for finding TDC for any particular cylinder you'll have to let me know what's a good way to find it. Prolly like shortly before the cams start to open the exhaust valves right? I dunno how close. Get pictures
here's a chart of what each valve is.
[Image: valveadjustment.htm]
from
http://www.dieselgiant.com/valveadjustment.htm
This post was last modified: 12-31-2010, 10:32 PM by larsalan.
from
led-panzer
12-31-2010, 10:36 PM #5
Cool thanks Smile
led-panzer
Cool thanks Smile
01-02-2011, 11:00 AM #6
If you can turn the engine at all by the steering pump, the belt is way too tight.
All you need is a 27mm deep socket and a ratchet to turn the engine correctly by the crankshaft.
01-02-2011, 04:46 PM #7
Really? I turned it that way to do the valve adjustment and it seems like there is good deflection on my belts.
Someone told me to turn it that way because it is easier to reach than the 27mm on the crankshaft. Maybe they had said to tighten up the belt just for the purpose of turning over the crankshaft
01-04-2011, 11:25 AM #8
I just throw a breaker bar with the 27mm socket on the crank bolt. You will have plenty of leverage and can be extremely accurate, which is what you need when you time the IP.
01-04-2011, 01:04 PM #9
Yes do not use the PS pump...
led-panzer
01-05-2011, 04:04 PM #10
Haven't gotten to it yet anyway, this car being my daily driver and now only vehicle has made me a bit of a chicken shit about messing with something that important.
led-panzer
 7 Guest(s)
 7 Guest(s)
