STD Tuning Engine 603 pump
603 pump
603 pump
Atli
01-09-2011, 12:43 PM #1
Hi
My engine 603.960
My pump nr is 0400 076 986
Can I use 0400 076 975 pump from 124 1988 300D
http://en.bildelsbasen.se/?link=item&post_id=20304116
Thanks
Regards
Atli
Atli
Hi
My engine 603.960
Thanks
Regards
Atli
01-09-2011, 08:06 PM #2
Yes, but you will lose 40hp because that one is for a non-turbo engine.
Atli
01-10-2011, 02:37 AM #3
(01-09-2011, 08:06 PM)ForcedInduction Yes, but you will lose 40hp because that one is for a non-turbo engine.
I thought I sow ALDA on the picture with it!!
Are you shoer it is non turba?
Regards
Atli
Atli
Regards
Atli
01-10-2011, 02:52 AM #4
That on top is the shutoff actuator. Middle back is idle speed control. Bottom back is anti-jerk control which means that pump was for a manual transmission, which also means it was non-turbo since MB didn't make any turbo models without an automatic.
tomnik
01-10-2011, 03:39 AM #5
Hi Atli,
either get a turbo governor or get a complete turbo IP.
Currently I am "playing" with different pumps and adjustments.
My 603 turbo pump with 7.5mm elements is out of the car for readjustment of the governor as I was not totally happy with the adjustment.
Right now I am installing another pump with 7mm elements which was originally for a friend but he sold his car before my pump guy could finish it.
A third pump is in progress for 7.5mm elements and adjustment according the results of the first.
Somewhen I can offer you a pump (7 or 7.5mm) that was already tested in the car.
Depending on your schedule this can be an option.
Tom
(01-10-2011, 02:37 AM)Atli
Regards
Atli
tomnik
Hi Atli,
Tom
Regards
Atli
Atli
01-10-2011, 03:55 AM #6
(01-10-2011, 02:52 AM)ForcedInduction That on top is the shutoff actuator. Middle back is idle speed control. Bottom back is anti-jerk control which means that pump was for a manual transmission, which also means it was non-turbo since MB didn't make any turbo models without an automatic.
Hi ForcedInduction.
Thank you very much for your help.
here is one more
http://en.bildelsbasen.se/?link=item&post_id=18651367
My pump 0400 076 986
This pump 0400 076 961
Do you know if this is the right one?
Regards
Atli
This post was last modified: 01-10-2011, 04:03 AM by Atli.
Atli
Hi ForcedInduction.
here is one more
Regards
Atli
01-10-2011, 04:08 AM #7
I can't really tell. Nothing in the description says for sure if its turbo or not.
Atli
01-10-2011, 04:26 AM #8
(01-10-2011, 04:08 AM)ForcedInduction I can't really tell. Nothing in the description says for sure if its turbo or not.
What about this one?
Chassi no. Model year: Milage: Fuel:
WDB1241931F250647 1993 51.454 -
Colour: Colour code: Interior: Interior code:
GRÖN - SVART-SKINN -
Gearbox: Gearbox no: Gearbox ratio: Group code:
AUTOMAT - 2,65 -
Engine: Engine code: Manufacturing date: Registration date:
603A.960 - - 19980626
Description:
5DR HGV 300 TDT AUT AUTOM
Jämför demonterade fordonets information mot ett registreringsnummer.
Atli
AUTOMAT - 2,65 -
Description:
01-10-2011, 04:31 AM #9
There you go. I really like those seats.
tomnik
01-10-2011, 04:47 AM #10
Atli,
the ... 961 is a turbo pump
and 124 193 ..is also an indication for turbo.
But 260 EUR is (too) much for that.
max. 150 EUR for a nice one o.k. but 260 ?
Tom
tomnik
Atli,
Tom
Atli
01-10-2011, 05:13 AM #11
(01-10-2011, 04:47 AM)tomnik Atli,
Tom
Hi Tom
Thanks for the info.
I'm might get this pump for 220ERU but I'm checking that out.
I don’t know how to get my pump back from David so I'm going to buy new one and send it to PP tuning in Holland for 7mm mod.
Do you know where I can buy a pump from 150ERU?
Is there any anther than David doing your 7.5 element mod?
I appreciate your help
Regards
Atli
Atli
Tom
Hi Tom
Regards
Atli
tomnik
01-10-2011, 05:37 AM #12
from time to time a turbo pump comes up on ebay.de for that money or less.
Did you contact Scott for your pump that you sent to David?
Arjan can also install the Floyd elements...
As I wrote before I am sending back my Floyd IP to Berlin for a re-adjustment of the governor (on guarantee) and collecting the settings.
This pump or the one with the 7mm elements will be for sale after I tested them in my car and have the third pump running.
Tom
tomnik
Tom
Atli
01-10-2011, 06:40 AM #13
(01-10-2011, 05:37 AM)tomnik from time to time a turbo pump comes up on ebay.de for that money or less.
Tom
ok I will look into ebay, they are about 3-400 USD in us.
No I dont have scott's info.
ok how is your 7mm pump working?
maybe you can send me price in PM?
I have run out of time long time a go so I really need things to go fast frm now on.
Anather thing. I Iceland orginal piston rings cost 1250ERU, I did buy rings for 220USD frim germanstar.net but theyreally look cheap and I dont want to use them. What do you think some good quality piston rings would cost in germany?
Thanks agen for your help
Regards
Atli
Atli
Tom
Regards
Atli
 7 Guest(s)
 7 Guest(s)
