STD Tuning Engine OM616 v OM617
OM616 v OM617
OM616 v OM617
  • 1 Vote(s) - 4 Average
01-29-2011, 09:08 PM #1
Are these engines similar internally other than piston oil spray and different pistons in the 617?
DieselSchlepper
01-30-2011, 12:46 AM #2
Yes they are very similar engines.
josha37
Turbo 616
18
01-30-2011, 01:14 AM #3
For my 616's sake i would hope so Wink
josha37
01-30-2011, 06:02 AM #4
So then, the 616 will easily handle similar boost, with the piston skirt oiling done?
DieselSchlepper
yankneck696
395
01-30-2011, 06:43 AM #5
I believe you will find a nitrided crank & higher capacity oil pump, too.
Ed
yankneck696
Ed
MTUPower
288
01-30-2011, 10:49 AM #6
Valves are different- turbo ones can handle higher heat. Please be a guinea pig and tell us via direct experience what you find.
MTUPower
yankneck696
395
01-30-2011, 12:10 PM #7
6-8 PSI seems to be the point safety. More than that & UPGRADES !!!
yankneck696
George3soccer
01-30-2011, 02:20 PM #8
It should be able to take more boost, once installing oil spray, and installing a good oil cooler. Just make sure it runs cool, and you should have not much problems.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
josha37
Turbo 616
18
01-30-2011, 02:24 PM #9
lol, if it helps any my 616 is getting 20 lbs max manifold pressure. Smile
josha37
yankneck696
395
01-30-2011, 07:50 PM #10
(01-30-2011, 02:24 PM)josha37 lol, if it helps any my 616 is getting 20 lbs max manifold pressure. Smile
Cool !!! What exactly have you done?
Ed
yankneck696
Ed
josha37
Turbo 616
18
01-30-2011, 09:28 PM #11
Exactly? heh... first thing i did was remove anything factory exhaust related and fabbed up a pipe to connect the factory manifold to a turbo off a diesel dodge d20 pickup. then removed the ada, adjusted the torque capsule, adjusted the high idle, removed the rack limiter, stretched the fuel return spring, adjusted the delivery holders, and... thats all i can think of at the moment. On the list of to-do's is a intercooler and pre-chamber modification. I am wasting ALLOT of diesel Wink, the exhaust exits directly behind the passenger front tire so that is about as low restriction as it gets which is nice but... it makes the car very dirty. Oh and turned the trans line pressure adjustment in something like 5-6 ish turns but i need to go a little furthur when it gets warmed up it will slip a bit under heavy load but only during shifts.
This post was last modified: 01-30-2011, 09:35 PM by josha37.
josha37
01-30-2011, 10:43 PM #12
(01-29-2011, 09:08 PM)DieselSchlepper Are these engines similar internally other than piston oil spray and different pistons in the 617?
No. They have no engine part designs in common beyond the cylinder head casting and injection pump. josha37 doesn't have a clue what he is doing and is following the advice of one person that has even less understanding.
The block, crank, rods, piston pins, pistons, prechambers, camshaft, oil pump and valves are all different to handle the stress of a turbo. You need to read this before considering adding a turbo: http://papers.sae.org/780633/
This post was last modified: 01-30-2011, 10:46 PM by ForcedInduction.
01-31-2011, 04:23 PM #13
Guess I missed all the excitement!
01-31-2011, 08:16 PM #14
Thanks: Wondering how in India they are producing the OM616 in turbo. Low boost or did they do extensive mods?
DieselSchlepper
casioqv
OM602 Turbo
116
01-31-2011, 08:32 PM #15
I'd wager that a regular OM616 would handle stock OM617a boost levels for a very long time without problems. Longer perhaps even than many other purpose built turbo diesel engines. The modifications done to factory turbo motors aren't strictly necessary, but increase durability and longevity in a manner consistent with the Mercedes Benz practice of severely over-engineering, and under-tuning everything. A practice that leads to their legendary reputation for longevity...
When the OM617a was released there was also very little knowledge/long term data on longevity of turbocharged passenger car IDI diesels which gave Mercedes reason to be extra careful. In hindsight 30 years later I think the engineers would realize that they could have tuned these engines for a bit more power and/or omitted some of the modifications done to the turbo engines and still retained excellent longevity and reliability. Instead they ended up with an engine that can easily outlive both the people driving them, and the chassis it's installed in.
Another factor that I think often escapes home modders is the extreme environments a stock un-modified car is engineered to survive. A stock Mercedes turbo diesel can, for example survive regularly climbing steep grades fully loaded at full throttle in 120F heat for decades on end. People whom don't subject their cars to this type of extreme use (people whom perhaps aren't professional taxi drivers in Africa) can still experience good longevity tuning their engines to produce significantly more power however the stock cooling and other systems wouldn't handle those power levels long term in certain extreme conditions.
This post was last modified: 01-31-2011, 08:50 PM by casioqv.
-Tyler
No mercedes (for now)
casioqv
-Tyler
02-01-2011, 07:01 AM #16
It's amazing the passion the Germans have for strength and endurance. I own several Deutz aircooled engines, one of which I put into an old pickup, just for fun, and I'm constantly impressed with it. It's an F5L 912. The Deutz are known world over for longevity. I have a friend shopowner who has seen the F4L 912 last over 20,000 hours. I have another 5 and a 4. They give rough muscular power as you might imagine from about 1 liter per cylinder. The five is a 4.9 and in good weather with number 1 diesel I've gotten 26-27 mpg and I'm on it all the time. This is what has lead me to the Mercedes and the OM617. I want to get several of them before they get scarce. Thanks for the great answers.
This post was last modified: 02-01-2011, 07:05 AM by DieselSchlepper.
DieselSchlepper
02-01-2011, 12:46 PM #17
(01-31-2011, 08:16 PM)DieselSchlepper Thanks: Wondering how in India they are producing the OM616 in turbo. Low boost or did they do extensive mods?
Force Motors (Tempo) basically made a 617a - 1 cylinder after they licensed MB's design. Even the transmission is a licensed MB clone. 90hp was factory.
This post was last modified: 02-01-2011, 12:50 PM by ForcedInduction.
dude99
02-01-2011, 04:33 PM #18
whats the air filter setup on that motor. i can't see it. Oil bath?
dude99
yankneck696
395
02-01-2011, 05:25 PM #19
So, while building this engine in India, did they use ALL of the upgrades that the 617a did? Would there be anything they skipped?
Ed
yankneck696
Ed
casioqv
OM602 Turbo
116
02-01-2011, 05:31 PM #20
Man, those force motors vehicles seem really cool. They don't just copy the MB engines- but the chassis too.
Traveller aka sprinter:
[Image: traveller_3050.jpg]
Trax aka G-wagen:
[Image: gurkha4wd.jpg]
Supposedly they now have a direct injected engine based off the OM616. I wonder if the head and pistons could be used on a regular 616 to convert to direct injection?
This post was last modified: 02-01-2011, 05:34 PM by casioqv.
-Tyler
casioqv
Trax aka G-wagen:
-Tyler
02-01-2011, 06:42 PM #21
(02-01-2011, 05:31 PM)casioqv I wonder if the head and pistons could be used on a regular 616 to convert to direct injection?
No. The deck height is far too short to support direct injection pistons.
casioqv
OM602 Turbo
116
02-01-2011, 06:58 PM #22
(02-01-2011, 06:42 PM)ForcedInduction No. The deck height is far too short to support direct injection pistons.
I'm not really sure what this means, but they do claim to have "further developed" the OM616 into a DI engine:
Quote:The famous 'Mercedes' OM-616 engine made under license has been further developed with Force Motors's own R & D and with assistance from M/s. Ricardo of UK & M/s. AVL of Austria, to create a large and modern facility of IDI, Direct injection, turbo / intercooled and Tractor Engines.
http://www.forcemotors.com/power_pack_ma...uring.html
That could perhaps even be a mistake or mistranslation, because the photos of the engines on the assembly line below that quote look more like N/A OM602s to me.
This post was last modified: 02-01-2011, 07:00 PM by casioqv.
-Tyler
casioqv
-Tyler
02-01-2011, 07:57 PM #23
They're taking liberties in the interest of advertising.
What's the weight of these engines anyway?
This post was last modified: 02-01-2011, 07:58 PM by DieselSchlepper.
DieselSchlepper
02-01-2011, 08:59 PM #24
(02-01-2011, 07:57 PM)DieselSchlepper They're taking liberties in the interest of advertising.
Agreed.
Probably the only mechanical similarities between the two are the boreXstroke dimensions.
Deck height means the total height of the block from the crank centerline to the top of the...well...deck. Ever notice how thick our cylinder heads are compared to other engines? Thats because the combustion chamber is in it instead of the piston. The blocks of DI engines are taller to support the taller pistons.
This post was last modified: 02-01-2011, 09:00 PM by ForcedInduction.
Agreed.
casioqv
OM602 Turbo
116
02-01-2011, 09:02 PM #25
(02-01-2011, 08:59 PM)ForcedInduction Ever notice how thick our cylinder heads are compared to other engines?
Actually the OM61x has the thinnest cylinder head I've ever seen on an overhead cam motor... mostly because the most of the valvetrain is mounted above, rather than inside the head.
This post was last modified: 02-01-2011, 09:02 PM by casioqv.
-Tyler
casioqv
-Tyler
 16 Guest(s)
 16 Guest(s)
