What should I look for?
I like the idea of the OM617. I guess that means 1981 to 1985 W123's. Any exceptions, anything more desirable?
Earlier too. People are liking the older manifolds.
http://en.wikipedia.org/wiki/Mercedes-Benz_OM617_engine
IMHO, if your capable of an engine repower then EGR removal is of no concern as there are $30 kits available to block off the holes in the intake and exhaust manifolds. I made my own in about 30 minutes. If one eliminated all options with an EGR it would reduce the majority of the available OM617 turbo'ed models from which to choose.
I claim no expertise but from my readings the OM617.950 with 110 hp used from 1978 to 1980 didn't come with an EGR. The OM617.951 and 952 used from 1981-1985 was 125 hp and came equipped with an EGR. So the OM617 turbo we are referencing was sold in the US for 8 years of which the 1st 3 years it had no EGR and 15 less HP. One eliminates 63.5% of the potential donors by choosing only engines produced without an EGR (assuming an equal number of OM617's from each year are still available) along with the loss of 15 HP. $30 or 30 minutes eliminates the EGR. While I also would prefer to have the non-EGR intake and exhaust manifolds to transplant on to a 125 HP OM617, finding them for $30 is not likely in my part of the woods.
That's the logic to my position. If the information is inaccurate please correct it. Thanks!
So whom makes the EGR blocking plates?
I'm looking for a set for my OM602... I'm guessing when the EGR valves get old, simply disconnecting the vacuum line from them isn't sufficient to stop all exhaust recirculation?
http://www.peachparts.com/shopforum/show...hp?t=92534
Here's a thread on blocking off the EGR on an OM617. I don't have any knowledge of the OM602, but on my OM617 the port in the intake manifold to the EGR was completly stopped up with gunky carbon type of deposits. I don't think any gasses could have reached the EGR so disconnecting the vacuum lines would have probably been fine. Since I had the intake manifold off, I wanted to clean it out to improve the air flow and wanted the eliminate the EGR for both weight and appearance. Hope this helps.
Some advance the idea that if an engine is designed to run with ERG removing actually hurst performance.
My understanding is that the EGR systems are designed to deactivate at high throttle so really no engine is "designed to run with EGR" under heavy load. In this case, removing the EGR can't affect engine output at high throttle openings one way or the other. But at part throttle, I can't imagine replacing a significant volume of your intake air with low-oxygen exhaust could possibly do anything to improve performance. With the EGR removed, you can always re-adjust or remove the ALDA to burn more fuel with the extra oxygen now available.
I don't think maintaining EGR on an old diesel is a realistic option in any case, since they rarely still work after a few decades and getting them working again would require expensive dealer-only parts. Every old diesel I've owned had a worn out EGR valve that sprays oil around the engine bay until it's blocked off. I'm guessing these valves eventually get permanently stuck either open or closed (not sure which).
(02-03-2011, 02:10 PM)casioqv So whom makes the EGR blocking plates?
(02-04-2011, 03:04 PM)DieselSchlepper Some advance the idea that if an engine is designed to run with ERG removing actually hurts performance.
I remember what was said: If the engine is designed to run with the cylinder volume partially filled with exhaust gas, then fuel/air must be supplied to make up the difference.
<<The OM61x and OM60x engines were not designed for an EGR.>>
Then why did the designers design them with them?
Ed
(02-06-2011, 09:47 AM)DieselSchlepper If the engine is designed to run with the cylinder volume partially filled with exhaust gas, then fuel/air must be supplied to make up the difference.
(02-06-2011, 05:23 PM)yankneck696 <<The OM61x and OM60x engines were not designed for an EGR.>>
Ed
(02-06-2011, 05:23 PM)yankneck696 Then why did the designers design them with them?
