STD Maintenance General Stall after couple seconds of start up
W116Lorinser
OM617.95
147
02-08-2011, 11:28 AM #1
very weird only has been happening in the past 2 months on my w116 300sd om617 everything is new in the car the battery, glowplugs, oil, all filters, recent valve adjustment etc.
The car starts up right away but i have to hold the gas pedal down for a couple seconds before the engine fully turns over and runs perfectly.
If i dont hold the pedal down it runs for a second or two then stalls and shuts off. Do i need to adjust my idle higher or something? or is this normal for a older diesel in this cold weather.
W116Lorinser
02-08-2011, 06:56 PM #2
How much of the pedal are you pressing down?
Usually when you have a start and stop, it means you have an air leak somewhere.
dieselboy
Rotatin 5500 times a minute
680
02-08-2011, 07:17 PM #3
Is your primer pump leaking?
Edit: ^ whoa! New sig pic ftmfw!!
This post was last modified: 02-08-2011, 07:18 PM by dieselboy.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
W116Lorinser
OM617.95
147
02-09-2011, 11:55 AM #4
No primer pump leaks. Everything in engine in pretty much brand new.
I have to depress pedal for about 10 seconds or less then it runs perfect as usual.
I use delvac 15-40 non syntetic. Since its been real cold this winter in the northeast can this be a problem. I was thinking of changing to mobil 1 5-40 turbo diesel formula today since im due for a oil change.
The cars a 1980 with close to 200k. Can this be normal with a high mileage engine?
W116Lorinser
dieselboy
680
02-09-2011, 04:19 PM #5
My car does the same thing when it's cold but I think my primer has a small leak allowing air into the system.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
DrewGerhan
101
03-09-2011, 03:10 PM #6
My car does the same thing but only after a long drive (hour or more). If I go to restart quickly after shutting off I have to floor it for the first seconds to keep it running or it will sputter and die. If I open the gas cap there is a huge whoosh of air (vacuum). After this it will start normally until the next long drive.
I assume its my tank vent clogged up somewhere. Just haven't really dug into it much yet to verify.
DrewGerhan
03-09-2011, 03:40 PM #7
(03-09-2011, 03:10 PM)DrewGerhan My car does the same thing but only after a long drive (hour or more). If I go to restart quickly after shutting off I have to floor it for the first seconds to keep it running or it will sputter and die. If I open the gas cap there is a huge whoosh of air (vacuum). After this it will start normally until the next long drive.
The vent/valve is a bell looking thing. Could be clogged it is under the car.
[Image: snap_10.jpg]
DrewGerhan
101
03-09-2011, 04:46 PM #8
I did look at that and take a coat hanger to it. Didn't seem to be stuck and no debris came out. Thats all I've done though.
DrewGerhan
W116Lorinser
OM617.95
147
03-10-2011, 01:24 AM #9
(03-09-2011, 04:46 PM)DrewGerhan I did look at that and take a coat hanger to it. Didn't seem to be stuck and no debris came out. Thats all I've done though.
Wow i never paid attentioN to that part. Where is it located exactly. I have a 300sd w116 chasis.
ThanksSmile
W116Lorinser
ThanksSmile
03-10-2011, 08:12 AM #10
on my w123 there are 3 lines coming out of the fuel tank. All were rusted and leaking.
1 supply
1 return
1 for that vent
the valve opens both directions under minimal pressures.
the valve was like under the rear seat floor pan.
This post was last modified: 03-10-2011, 08:17 AM by larsalan.
1 supply
1 return
1 for that vent
