Holset HX35 Install info on om603
(02-07-2011, 10:46 AM)jonbobshinigin While I am saving up for a Myna Build, I plan on turning my pump up to full load, and installing an Intercooler. I have decided to use the passenger side area in front of the wheel well.
(02-07-2011, 03:09 PM)jonbobshinigin Which particular model is this off of? Any more photos?
The saab intercoolers are too small for a 3L engine, especially a 603, the flow restriction offsets more efficiency than the cooling gives. Volvos are the worst though.
So what would you recommend for something to handle Full Load adjustment that will also fit under the wheel well area? The ultimate option would be an AMG style bumper and a full IC, but that it more money than I have right now and obviously would not make sense until I had a Myna. Also, I am not wanting to go Water to Air right now.
(02-07-2011, 04:01 PM)ForcedInduction Volvos are the worst though.
(02-07-2011, 04:07 PM)jonbobshinigin So what would you recommend for something to handle Full Load adjustment that will also fit under the wheel well area?Small and high flow is a difficult job to fill. Pretty much all that fits the bill are A/W cores. A TDI intercooler would be a better compromise than a Saab since its twice as thick.
Quote:I'll bet the Volvo intercooler is one of the best ever sold in a stock turbocharged passenger car, considering it's massive size, but I don't see how you'd fit it in any Mercedes.Um, have you ever measured the pressure drop across one? Even on a stock car? Considering the above statement, I'd say no.
Quote:When comparing flowrates keep in mind that the OM603 only revs to ~4600rpm (I think that's right, can anyone confirm that?) whereas those "small" gasoline 4 cylinders rev to ~7000rpm actually flowing higher air volumes than the OM603 at comparable boost levels.That is false. Its rare for a stock g@sser to revv that high.
That looks very interesting Forced! Also very clean looking. Now would that be enough cooling power to keep up with a Myna? My guess it that it would not, in which case I would style like something for my "Stage 1"/Full Load + Intercooler behind fender. Do you have a recommendation for something adequate for that application?
I think the cheapo AW intercoolers on ebay are probably the best way to go. The only downside is that they use AA cores instead of AW cores. However they appear to flow plenty for our needs and are pretty compact. Like this one :
http://cgi.ebay.com/ebaymotors/12-25-X12...ccessories
Check this puppy out :
http://cgi.ebay.com/ebaymotors/Custom-Un...3271wt_941
(02-08-2011, 10:42 AM)jonbobshinigin Now would that be enough cooling power to keep up with a Myna?For a little 15psi 4-banger, sure. For a 20-30+psi Myna engine, definitely not. Little short of a full sized front or top mount intercooler would work for that. Even A/W would need something twice the size of the core I've got (10x4.5x4.5).
Quote:Do you have a recommendation for something adequate for that application?The TDI IC is a better fit.
(02-08-2011, 05:09 AM)ForcedInduction The drop on a stock 9psi engine can easily be upwards of 1psi, very restrictive. A decent core shouldn't see more than 0.25psi drop at maximum flow and boost.
(02-08-2011, 02:18 PM)casioqv I don't think you can make a clear cut comparison between the Volvo intercooler and a smaller one that has less flow restrictionI did. The large pressure drop offsets the better cooling with higher turbo drive pressure. Its a balancing act; high flow, high cooling or a little of both. A free flowing intercooler that doesn't cool very well is better choice than a very restrictive one that gets the temperature near ambient.
Quote:Any vehicle which could fit it could use the Isuzu NPR intercooler instead which is about the same size/shape as the Volvo with much less flow restriction.Or pretty much any core if such a large amount of space is available. The only marks in the Volvo favor are its cheapness and common availability.
Quote:Stock boost is set even lower than that (5-6 psi) but the stock intercooler still seems to work well with it raised to ~15psi.Yes, I understand there is even a factory "overboost kit" that allows 13psi for a limited time.
If make small accelerations, Chinece coolers are good enough. If need to drive fast long times just need choise better cooler core.
Stock 603.96x rev limit is 5150rpm, ±250rpm. Tranny upshift at WOT is ~4800 but I tweaked mine to ~5000. Peak power is down around 4600, but the engine has useful delivery to at least 5k. The Finns are spinning them up even higher but 5k is fine with me.
Does anyone know if an Intercooler would fit behind an original Lorinser front bumper?
(03-08-2011, 11:57 AM)jonbobshinigin Does anyone know if an Intercooler would fit behind an original Lorinser front bumper?
I am just looking into acquiring one actually...but I need to know if it will allow for an intercooler. Any idea what a new Lorinser bumper would run?
(03-08-2011, 12:43 PM)jonbobshinigin Any idea what a new Lorinser bumper would run?I'm sure you'd faint if you got a price. I'm also pretty sure the Lorinser items are no longer available new. But they should allow room for an IC; you can probably tell if you can get decent photos.
Are the durakits okay? Would AMG bumper be better for fitting an intercooler behind? Im getting the bumper either way, I just wanna know which would be better for an intercooler. Also, is there something besides a a Lorinser that I can put on the rear to match this front Lorinser?
Have any of you considered water-intercooler?
It shuld be possible to incorporate in the original air supply over the engine, and will not need any big hoses.
The w140-manifold pictured earlier in the tread looks very mouch the same as the standard manifold on all 603 turbos sold in Europe (all years from 1987 to1996).
The pictures located HERE are from my engine compartment. None of the manifold specially, but it can be seen in some of the pictures.
00012 is the only one showing some of the manifold. I can take some more pictures if requested.
The car is my 1992 300TD Turbo , euro.
This manifold is NOT suited for tuning, and is considered the main reason that almost all cylinder heads on the OM603 turbos get cracks and must be changed. I changed mine at 400.000 km (250k miles). It had cracks on 3 cylinders.
The design of the manifold causes too high temperatures.
How would the HX40 work with a standard IP? I want to tune my car, but I want to start with exhaust, manifold and take it from there.
(03-12-2011, 10:03 AM)frodes Have any of you considered water-intercooler?I've used it for over a year. I like it quite well.
Quote:and is considered the main reason that almost all cylinder heads on the OM603 turbos get cracks and must be changed.The manifold has no effect on cracking from overheating.
Quote:How would the HX40 work with a standard IP?Extremely poorly. Its slow to spool even on the 8.3L 300hp engine its designed for, it wouldn't spool more than a few psi with less than WOT at high RPM on a 603.
you are of course free to mean what ever you want to about the stock manifolds. Ask any serious tuner, they'll tell you the design is useless.
I don't know if the problem with cylinder heads cracking is the same on US versions. On euro spec, they all need replacing at 300-450.000 km.
Adjusting the turbo pressure and diesel delivery only makes the problem worse. Yet, the bad ass setups with twice the original output or even more, seem to do just fine as long as the flow is optimized.
What would be a good working turbo with stock IP, yet being ready for up to 250-280 hp?
Any more info / pictures of your water intercooling? I've only seen it installed in an 1994 E280 with twin turbo.
The Brand New, Genuine Lorinser Front bumper is in my possession! I am very excited and pictures will be up soon...hopefully tomorrow! I feel like I kind of found a goldmine.
It says Lorinser 488 2021. Made in West Germany
(03-12-2011, 12:28 PM)frodes Ask any serious tuner, they'll tell you the design is useless.Ah, so thats why every manufacturer in the world uses the design.
Quote:I don't know if the problem with cylinder heads cracking is the same on US versions.ALL 603 14-18 version heads crack due to casting design flaws, not the manifold.
Quote:What would be a good working turbo with stock IP, yet being ready for up to 250-280 hp?An HY35 or HE341 would be more than enough for that power range and up to 36psi boost.
(03-13-2011, 01:24 AM)ForcedInduction ALL 603 14-18 version heads crack due to casting design flawsOnly #14 and #15 heads had the weak design that was crack prone.
Haha...very true. I figured someone would say something about that. Now what to do with this bumper, sell or install?
Anyone know the part number for the impact strip? Is it same as stock?
I have also heard that the head cracking problems dont appear with another turbo manifold.
Offcoarse, if the engine is too hot, yes, but they are cracking even W/O too hot engine.
A restrictive exhaust manifol/turbo will make the EGT higher, and the head will get hotter.
I have a cracked #16head here, cracked on 5 cylinders.
(03-30-2011, 10:48 AM)Einar I have a cracked #16head here, cracked on 5 cylinders.
Okay, so I have this puppy just sitting here beckoning me to install...what will I need to do to make the HX35 Spool in a practical manner for daily driving without a pump upgrade? As long as it does not kill my MPG tremendously I am okay with a little less spool time...I will do the full load adjustment as well, and probably install the bumper and intercooler soon after.
The coolant pipe from the tstat housing to the aux water pump. On the 603 with the federal manifold its a snake that comes up and interferes with the euro manifold, as you pointed out earlier
Oh that...I have not tracked one down still...What did you do to remedy that? I have not thought about it for a while so it is not fresh in my mind :-) I am just getting antsy to get this thing installed!
PS - I am searching now and just stumbled across your benzworld post requesting one. Ha!
This project is alive again...DPUK 6mm Pump is installed along with Holset HX32. Photos to follow!
It is a legit HX32! And yes, I have heard nothing but how mysterious they are. I will have specs from Holset on it soon! More info in Signature link.
Supposed Specs:
Comp Inducer 54mm
Turbine Inducer 52mm
12cm Turbine Housing
Nice. I have a similarly sized BW turbo. What cc is your pump? As long as I don't have any intake leaks it performs pretty well. A little laggy in 3rd at low throttle but top end is great. Fuel kicks in around 2700. I have a custom manifold that has somewhat long tubes though
130CC from the 6mm DPUK....I am having issues spooling the HX32. I am seeing maybe 5 psi at 3500 rpms then it will shoot up to 20-25 for a quick second at 4500rpms. Very frustrating. No boost leaks but maybe an exhaust leak at the flex pipe between the two parts of the exhaust.
