single-mass flywheel for 603 ?
hi!
witch single-mass flywheel fits easily on the motor?
so I can keep the series 5 speed transmission?
i tought at one of the 200D OM601?
I want to edit me a flywheel that I can fit another clutch.
adjusts the transmission spike in the middle to the other flywheel?
starter wreath `?
is the flyweel surface flat? so the bolts dont stand up? then i coud take every plan clutch disc. and pressur plate. that would be my plan..
thx
Hi,
I believe there are stronger clutches for the G.
Check out on http://www.viermalvier.de/ubb_portal/ubb...1/Mercedes
Tom
