STD Tuning Engine Help! OM606 electronic injection pump
gen3performance
I like the smell of No. 2......
89
03-07-2011, 07:39 PM #1
Any idea how to remove this hose from the back of the IP? It goes from the back of the pump, across the engine, then to some coolant control valve or something.
http://s776.photobucket.com/albums/yy42/...20trouble/
1981 300SD...Too much propane = bent rods. Junked
1980 240D...Body fell off. Saved drivetrain and junked
1985 300D...No.2 and N2O = 16.35@85mph. Sold Sad
1999 E300TD...3" exhaust with banks muffler, Hx-35, 215hp tune, IP resistor box, bad crankshaft snout Angry
2005 E320 CDI...AMG injectors, EGR removed, mapping
Vids! http://www.youtube.com/user/silverado408
Pics! http://s776.photobucket.com/albums/yy42/...rformance/
gen3performance
03-07-2011, 08:36 PM #2
That looks like the electrical harness. Presumably there's a plug on the other end.
E300TSC
Turbo-Supercharged
321
03-07-2011, 08:59 PM #3
That's not a hose and it doesn't really disconnect from that end. Look at the firewall on the right side and you'll see a round connector, about 2" in diameter. It has a silver metal release on the side. Press this release with a screwdriver blade and the connector will literally POP off.
E300TSC
gen3performance
89
03-07-2011, 09:16 PM #4
Ha! That worked like a charm! Thank you very much!!!
gen3performance
