Delivery Valve Testing
Last night my buddy and I turned down a spare set of DVs that I had. We put the valve in a air drill that was in a vise and used a file to take away the collar. No nicks on the seat even. So we go to put them in. Once she fires after getting the air out the rpms just start climbing without touching the throttle at all and a huge plume of really dark grey smoke. Not so much black as dark grey. It didn't rev too high (less than 3500) before I shut it down.
After this, I put the stock DVs, springs and holders all back. They were all in their own bags as to not mix up between cylinders. Now it is slow to return to idle. Quick revs (under 1500rpm) in neutral in the driveway, it returns quickly. When driving at 40mph and I push in the clutch, it stays right around 2000rpm and slowly, if at all, comes down. It hasn't gone up in speed yet on its own after putting the stock DVs back in.
My question is, why? Why is it slow to return all of a sudden? The return spring that attaches to the bottom of the pump hasn't been on in over 2 years but the return spring closest to the pedal is fully capable of bringing the linkage back to idle.
It is totally possible that the DV holder could be upside down. Would this cause this condition?
^^^That is how they were installed with the cut DVs and putting the stock ones back in which now has the idle return issue.
^^^They are NOT installed this way currently.
Which is correct/does it make a difference?
(03-20-2011, 09:08 PM)DrewGerhan We put the valve in a air drill that was in a vise and used a file to take away the collar. No nicks on the seat even. So we go to put them in. Once she fires after getting the air out the rpms just start climbing without touching the throttle at all and a huge plume of really dark grey smoke. Not so much black as dark grey. It didn't rev too high (less than 3500) before I shut it down.I could have told you it works like crap 3 years ago when I did the same thing...
Quote:After this, I put the stock DVs, springs and holders all back. They were all in their own bags as to not mix up between cylinders. Now it is slow to return to idle.
Yeah I remember your thread Forced. I just wanted to see what would happen for me. Young and dumb I guess.
So mine are installed correctly. How can it be slow to return to idle then?
What is the idle rpm? If its set above 800rpm the governor won't cut fuel on deceleration.
I think it is above 800rpm. If turn it down to 750(stock?) it should act normally?
I did not touch the idle speed or timing at all when messing with the cut DVs.
When you do this kind of modification on the delivery valve, the pump deliver a lot more fuel on low idle, The racktravel with original valve is app 6 mm at low idle, then you have around 9-12mm3@1000 stroke of fuel, After mod you have to adjust the rack travel to 4-4,5 mm at low idle, otherwise the pump overfuels with the common idle problems that you have.
If you have a good dieseltech I am sure he can help you, but he need to customize the governor for this kind of application.
Do you mean you have to adjust the rack when the cut DVs are in? Right now the stock ones are back in and its doing the idle thing. Would it be because I removed the rack limiter?
My Turbo 617 idles right @ 1000RPM and has NO idle return issues.
Made a quick video just to show what is happening.
http://www.youtube.com/watch?v=Y4zVv2eZ0ig
My 300D has the same result after I adjusted the torque control.
So did mine, but nearly as bad.
(03-21-2011, 01:37 AM)dieselmeken When you do this kind of modification on the delivery valve, the pump deliver a lot more fuel on low idle, The racktravel with original valve is app 6 mm at low idle, then you have around 9-12mm3@1000 stroke of fuel, After mod you have to adjust the rack travel to 4-4,5 mm at low idle, otherwise the pump overfuels with the common idle problems that you have.
I tried some more to get it to behave but it wouldn't. Its weird. The first maybe 1/4 mile of driving, no matter what speed or rpm, it returns to idle fine. Once its past that first 1/4 mile though it all goes to shit.
Oh well. I said fuck it and put my last untouched spare pump on. The only one left is my M-pump which I don't plan on messing with.
(03-22-2011, 01:28 AM)tomnik(03-21-2011, 01:37 AM)dieselmeken When you do this kind of modification on the delivery valve, the pump deliver a lot more fuel on low idle, The racktravel with original valve is app 6 mm at low idle, then you have around 9-12mm3@1000 stroke of fuel, After mod you have to adjust the rack travel to 4-4,5 mm at low idle, otherwise the pump overfuels with the common idle problems that you have.
Hi,
sorry, but as a dieseltech you should know what a delivery valve has to do:
Reducing the residual pressure in the hard line after injection to avoid a second nozzle opening from the running shock wave.
One thing to alter the shape of the delivery curve is to grind a little flat on the collar but still the DV works as it is designed for.
Removing the collar completely is below garage tuning standard.
A DV is much more than a simple check valve.
At least my goal is not to create a smoking monster where the fuel is simply dumped into the cylinders.
Tom
Hi,
Tom
Hi Göran,
this was not against you and I don't call you a garage tuner!
Nearly everybody here is driving his car on the streets.
For them (me included) the delivery valve "tuning" as described should not be an option same with increasing rack travel over max. with stock/small elements.
The results are smoke, heat and stress for the engine.
For that reason I calculated and designed my elements. For tractor pulling some just big and only at a certain rpm range running cheap elements are sufficient.
We are in the position here in this forum that we have the knowledge how to get our engines faster without the image of old diesel smokers and bad economy.
At least here in Europe/Germany where all the todays diesels have a particular filter diesel smoke is something bad and we risk to get banned completely.
Besides that some basic interest in environment should be always there and again the forum has the knowledge to do it better.
Tractor pulling or specific racers is different story but here we should have the goal to get our engines perfectly running (minimum as good as stock when new).
Just my personal comment.
Tom
