STD Tuning Engine I feel like a tard, help me install my boost gauge
mike-81-240d
more like mike-84-300d now
427
04-10-2011, 08:18 PM #1
I tried following three different threads on peachparts with no results. What should I be doing here? I think this car has had the EGR deleted?
I'm lost, and im testing while driving not in park... Sad
the cars is a '84
[Image: DSC01483.jpg]
[Image: DSC01482.jpg]
[Image: DSC01481.jpg]
[Image: DSC01477.jpg]
[Image: DSC01479.jpg]
mike-81-240d
the cars is a '84
totaldisaster
lightly modded OM606
211
04-10-2011, 08:26 PM #2
Looks like you got it there, Homes.
If you are properly 'tee-ed' into that vac line for the egr, it should only see vacuum at certain loading conditions and during certain engine temperatures.
As long as that line is off the egr, its done.... oh, but the valve can leak a bit.
you can also delete the ARV on the front of the turbo. Its got a vacuum line to it as well. If you do do this, then an entire valve can be removed from your engine bay... (hint: I think you gave us a photo of it.)
Major Edit: I did not see you wanted to install a boost gauge, sorry. I thought you were looking to delete egr.
This post was last modified: 04-10-2011, 08:30 PM by totaldisaster.
totaldisaster
04-10-2011, 08:27 PM #3
I'm lost too. You didn't say how far you got.
Did you tee into the alda line?
mike-81-240d
427
04-10-2011, 08:37 PM #4
(04-10-2011, 08:27 PM)aaa Did you tee into the alda line?
I tried that, but didnt read any boost on the gauge. The line coming off the ALDA going to the firewall correct?
mike-81-240d
totaldisaster
211
04-10-2011, 08:39 PM #5
any line coming off the ALDA will work.
its easiest to tap into the rubber one on the end of the nipple.
You wont see boost until you put a load on the engine (driving... etc..) If you didn't see boost even when driving, perhaps your boost tube from the back of the intake manifold is broken or there is an incredible clog at the manifold or in the switchover valve on the firewall.
This post was last modified: 04-10-2011, 08:41 PM by totaldisaster.
totaldisaster
Rudolf_Diesel
Ask me if I care...
04-10-2011, 08:44 PM #6
Did you clean the banjo bolt on the manifold that feeds the ALDA? It can be clogged with soot and not allow any boost signal - maybe a problem with fuel enrichment as well when boost kicks in?
This post was last modified: 04-10-2011, 08:45 PM by Rudolf_Diesel.
Rudolf_Diesel
4rnnr33
04-10-2011, 10:58 PM #7
(04-10-2011, 08:39 PM)totaldisaster any line coming off the ALDA will work.
X2 you wont see any boost pressure until you actually drive it if you tee'd off the alda line your golden
4rnnr33
mike-81-240d
427
04-11-2011, 12:04 AM #8
Winner winner chicken dinner. When I tried tee'ing into the ALDA line the first time I guess shutting the hood with the plastic boost line running into the cabin kinked it. The car seems to pull about 9.5psi at 35 or so. More detail after I buy a gauge pod tomorrow.
This post was last modified: 04-11-2011, 12:05 AM by mike-81-240d.
mike-81-240d
mike-81-240d
427
04-13-2011, 08:39 PM #9
http://www.youtube.com/watch?v=IdhCG0203Tc
mike-81-240d
04-18-2011, 01:00 PM #10
Orange needles are pretty.
You want to check max boost on a long hill in 3rd at WOT. 12psi is about right.
 6 Guest(s)
 6 Guest(s)
