New Project - Skunkwerks EM9D
  • 3 Vote(s) - 5 Average
Pages (14): Previous 1 10 11 12 13 14
04-11-2011, 07:23 PM #651
Im a little late...
http://www.youtube.com/watch?v=Y4L3SvJryeY
http://www.youtube.com/watch?v=HoLETI8PrEg
http://www.youtube.com/watch?v=QaKwx-zx11Y
Im a little late...
SurfRodder
Jackass Extraordinaire
611
04-11-2011, 11:38 PM #652
(04-11-2011, 07:23 PM)garage Im a little late...
better late than never...
OBK# 62
SurfRodder
OBK# 62
led-panzer
07-13-2011, 09:48 AM #653
Hey Rudolph,
Where was the other end of your crankcase vent (after the 240 breather) connected?
1985 300D 280,000 miles RIP
led-panzer
Hey Rudolph,
07-13-2011, 01:36 PM #654
Pretty sure it was connected to turbo intake.
There was a surprising amount of oil in the Intercooled Intake manifold
led-panzer
07-13-2011, 02:58 PM #655
That's what I thought, where I was going with this is - if it was connected to the turbo intake, was the crankcase being pressurized by the supercharger?
led-panzer
300D50
Graphite Moderator, ala RBMK
07-13-2011, 03:02 PM #656
He likely had a backflow-prevention PCV valve in there someplace.
300D50
led-panzer
07-13-2011, 03:37 PM #657
I still don't see how that would work. Let's say it stopped pressure from entering, how would it vent when the valve was closed? To the atmosphere? How?
At some point hopefully he will stop by.
led-panzer
07-13-2011, 04:27 PM #658
I'll alert him to your question led
led-panzer
07-13-2011, 04:52 PM #659
Nah you don't have to bother him. I was looking at different setups because I need to make one, that and a few other things (like how much oil was in your intercooler) just made me curious, and since barely any of the pictures are up I couldn't find my answer on my own. No big deal
led-panzer
07-14-2011, 02:19 PM #660
I have wiped it out once already...
Rudolf_Diesel
Ask me if I care...
07-14-2011, 02:36 PM #661
I had it routed to the intake prior to the supercharger. I tried to route it into the turbo inlet, but the S/C puts out 2 psi at idle. The motor probably had some blowby as well, the valve cover cap would rattle if left to sit on top.
This post was last modified: 07-14-2011, 02:38 PM by Rudolf_Diesel.
Rudolf_Diesel
ben2go
Diesel Dumby
129
12-01-2011, 10:51 PM #662
What happen to the car RD?
ben2go
12-01-2011, 11:27 PM #663
Engine was taken apart, and now the rolling chassis and engine block/pieces reside at my residence.
ben2go
Diesel Dumby
129
12-01-2011, 11:40 PM #664
Good luck.Have you started a thread on the rebuild?
ben2go
12-02-2011, 09:17 PM #665
Nope, its pretty much my dads car, im not a fan of the w126.
The interior is PRISTINE and a beautiful chocolate-coffee colored brown.
Just gonna build a stock engine to put in it. Hes a old man that dosnt like to drive fastSmile
Cole
It's as easy as 1 - 2 - 3!
21
08-29-2012, 01:22 PM #666
this thread blew my mind, wow, amazing work, craftsmanship and attention to detail
(07-31-2010, 08:01 AM)ForcedInduction
(07-31-2010, 07:56 AM)Rudolf_Diesel That is for a ball bearing turbo, I am using a journal bearing turbo.
I quoted exactly what you posted in #250
http://www.superturbodiesel.com/std/new-...l#pid15318
Quote:I don't want to run into problems of not having sufficient oil and having the compressor wheel contact the housing - you know this well with your attempt at installing the Holset.
Do we REALLY need to go over this again. The holset's failure was NOT IN ANY WAY RELATED TO THE OIL SYSTEM.
There will be NO more discussion on that INCORRECT theory of my Holset's demise. It was 100% thoroughly disproven yet you people still clasp onto that completely incorrect idea. DROP IT, You're wrong. Simple as that. End. Of. Discussion.
now this is quality right here Tongue
This post was last modified: 08-29-2012, 01:23 PM by Cole.
1982 300TD - Wilber
1985 300TD - Ol' Blue (parts car)
1984 300D - Black Beauty (parts car)
various OM617 and 617A parts engine
"You have to realize that this is a DIESEL and you have a gasser for starters - what works for you will not necessarily apply to me. I for instance could run 35 pounds of boost and probably more and your engine would be a block with melted pistons. "
-Rudolf Diesel
Cole
1982 300TD - Wilber
-Rudolf Diesel
10-17-2012, 12:29 AM #667
Rudolf, what's up with you car? Any updates??
supercharged3.0
10-17-2012, 12:36 AM #668
The car got parted out.
08-13-2014, 10:55 AM #669
As I believe being chief ancient post excavator is perfectly aceptable so long as one contributes to the evoution and progression of the engineering design of the subject vehicle and OP, I would like to submit my design for plumbing a SC and turbo for the above engine.
Compounded of course, because who wouldn't?! Anyway this design minimises pipe length, maxismises simplicity (no bypassing) and allowss compounding of the boost of course, I am unsure why everyone fitting an eaton/similar and a turbo to a pre-crossflow mercedes diesel doesn't employ this method..
Note the amin issue with compounding a crossflow engine is there typically has to be a crossover pipe to allow dual-pass air-air intercooling, the non-crossflow mb engine fortunately allows this to be avoided as the inlet manifold is on the correct side assuming the below payout is adhered to.
Hopefully this will prove useful to someone in the future, just a nod to credit the idea will do, Wink Fortunately I am a fairly well versed engineer so my idea is actually quite good.. Haa!
[Image: SC-turbocompounddiagram.jpeg]
Thanks, H.
This post was last modified: 08-14-2014, 02:23 AM by Hario'.
Thanks, H.
 92 Guest(s)
 92 Guest(s)
