STD Tuning Suspension torching springs
torching springs
torching springs
04-30-2011, 07:51 PM #1
I was cutting up the heap today and this old time mechanic friend of mine walked by. He started telling me to save every bit of that car and that all of it could be worth money.
I had mentioned how people will cut the springs and that I had saved mine to sell them. He says cutting springs is dumb and what you should do is put heat on them while they are still in and when they shrink down blast them with a spray of water.
Ever heard of that?
Ever heard of that?
04-30-2011, 10:59 PM #2
Cutting springs can only be done effectively on certain spring types/shapes. For instance a w123 spring can be done effectively because of the shape of the lower spring perch.
Heating springs are an 'old school' method of lowering. You would torch the bottom coils until the desired height is attained. But with a modern car, the problem you run into is the spring rates will change with heating and you cannot be consistent with all the springs. So spring rates will be be random, and the ride will end up uneven and "floaty".
The other issue is the spring would be weakened. So the possibility for the coil to crack apart is great.
If the spring type allows for it, cutting with cutting disk is the best and only option.
dieselboy
Rotatin 5500 times a minute
680
05-01-2011, 02:15 AM #3
Heating springs is a no no. It makes the spring steel not so springy. It will break alot eaiser and will fail eventually.
This post was last modified: 05-01-2011, 02:16 AM by dieselboy.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
05-02-2011, 12:22 AM #4
+1
Cut only!
+1
Cut only!
300D50
Graphite Moderator, ala RBMK
05-02-2011, 08:49 AM #5
After seeing an Infinity in the yard that had a mild side impact and shattered a good stock spring on the other side, I'd say "stay the hell away with a torch".
300D50
okto
05-06-2011, 05:38 PM #6
Learn about annealing and hardening to see why heat-modifying springs is the worst idea. Unless you want to use your springs to make a knife. Tongue
1995 E300D 248,000mi and counting!
okto
