STD Other FS / WTB / Buying guides 300D 2.5 T parts
300D 2.5 T parts
300D 2.5 T parts
totaldisaster
lightly modded OM606
211
04-28-2011, 04:38 PM #1
OM602 turbo parts.
I have some access right now. No head or block.
Nice body, interior (dark grey on light grey)
nice set of injection lines
good turbo with a little wiggle on the shaft, vacuum actuated (holds vac)
other misc.
totaldisaster
OM602 turbo parts.
other misc.
05-03-2011, 08:39 AM #2
What year? Boost sensor located on soundwall infront of battery please.
totaldisaster
211
05-04-2011, 12:11 AM #3
Very doo-able.
you get speshow discownt.... website ownah, pay sheeppeeng onry.
PM your details I will get to you this weekend.
oh.... it was like '92 -ish. ya'know, vented passenger fender and vacuum controlled turbo WG. w124
This post was last modified: 05-04-2011, 12:18 AM by totaldisaster.
totaldisaster
Very doo-able.
totaldisaster
211
05-04-2011, 01:23 AM #4
1990, will that work?
You are talking about the EDS pressure sensor, correct? not the overboost switch....
totaldisaster
waz
05-04-2011, 09:53 AM #5
Did the cruise control work? I could use any parts related to CC that might be good.
Cruise control amp, servo, and speed control sensor from behind the instrument cluster. I've seen something about an encoder but, I'm not sure where that is just yet (heck the encoder could be one of the parts I mentioned or part of one for all I know).
The rpm sensor at the flywheel would be another item I might find useful.
Anything you could help with would be great.
Thanks,
Wes
waz
Thanks,
Wes
Jtn190D
MERCEDES DIESEL POWER!
192
08-04-2011, 08:19 AM #6
Are these parts still available?
Jtn190D
waz
08-04-2011, 07:19 PM #7
Don't know. Don't need any of the parts anymore either.
waz
08-15-2011, 03:30 PM #8
I need the tube that come from the tstat housing to the aux water pump. Should be a horizontal U instead of a vertical snake.
Should look like [Image: full]
08-15-2011, 04:29 PM #9
Darn there was a 2.5 at the JY a month ago.
