STD Other Non MBZ Diesel 4 cyl perkins only firing on two cylinders at idle?
05-15-2011, 12:57 PM #1
I have a 318 perkins in my "farm stock" pulling tractor. It has been bored and stroked to be almost 390 ci, also has a ground cam in it from crower. No head work except the angles on the valve have been touched up.
When at idle cylinders 1 & 2 do not fire, but when it is at WOT it runs fine? Confused
Any input is greatly appreciated.
dieselboy
Rotatin 5500 times a minute
680
05-15-2011, 06:30 PM #2
Id pull a injector line off a missing cylinder and do a ghetto jar timed cc test and compatr it ti a good cylinder If they are close then pop test the injectors.
Ve or inline pump?
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
Ve or inline pump?
-Jesse
70 f250 390
66 Volvo amazon
05-15-2011, 07:45 PM #3
(05-15-2011, 06:30 PM)dieselboy Ve or inline pump?
Lucas CAV Ve. Stock pump, but the injectors are laser cut 8 hole, not sure what size. It would be a good idea to test injectors.
The guy that does our pump work said he has seen this happen to engines where the valves in the cylinder head are not all seated equally (at the same depth)? Huh
Thanks for the input Smile
HoleshotHolset
05-16-2011, 09:28 AM #4
(05-15-2011, 12:57 PM)MFSuper90 When at idle cylinders 1 & 2 do not fire, but when it is at WOT it runs fine? Confused
It's a pulling tractor, it's supposed to idle funny and then run like a recently violated primate at WOT... Big Grin
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
05-16-2011, 01:56 PM #5
(05-16-2011, 09:28 AM)HoleshotHolset It's a pulling tractor, it's supposed to idle funny and then run like a recently violated primate at WOT... Big Grin
Hahahaha Tongue yes, but not firing at all on the front two isnt healthy. I only wish my cam was that big Wink
Biohazard
Smokin like a champ!
376
05-16-2011, 07:32 PM #6
recently violated primate... Jebus, I'm gonna steal that line from you. LOL My coworker was looking at me funny when I started laughing over here!
Have you checked leakdown on the cylinders?
Biohazard
05-16-2011, 08:19 PM #7
(05-16-2011, 07:32 PM)Biohazard Have you checked leakdown on the cylinders?
Unless the rings did not seat up correctly there shouldnt be hardly any considering we just built this engine about a year ago.
but i suppose it wouldnt hurt to check Tongue
thanks for everyones input Smile
john
01-11-2014, 09:16 PM #8
i think they have some strange prechambers where some things can come loose? Then it dont run on all cylinders when cold
Holset power!
john
Holset power!
01-13-2014, 08:41 PM #9
John, It's direct injection.
As after I converted it to a VE pump it helped with the miss some.
But I think it's mainly from the big cam and wild timing
hansendk
01-15-2014, 07:35 AM #10
well its some time since I played with 4.318 but for me it sounds like the valves have you checked the valve clearance if you run std exhaust valves the beating and heat can make so the valves are going up in the head so there is no compression when its idle but at rpm they are forced up so it running on all 4
is it worse when its hot then its a possibility
I have seen it on a lot on old tractors where nobody have adjusted the valves for decades symptom to look for it more difficult to start when its hot.
hansendk
03-08-2016, 06:48 PM #11
Hansendlk, you were correct partially correct. Two valve were sunk into the head not seating correctly and the port job that was done had a pinhole in the intake side cause it to suck a tiny bit of coolant in the cylinder. And it had two bad injectors. I just got all this taken apart and check the past month or two lol.
It's changed some though, now it has a Bosch VE on it and I just fabbed up a Borg Warner s257sxe on it, waiting for my injectors to come back now...
 14 Guest(s)
 14 Guest(s)
