STD Other Projects Throttle Linkage Upgrade
05-14-2011, 03:55 PM #1
I saw where Mr. Manny had a cable set-up for his acceleration - fuel pedal.
Has anyone done this in a W123 ? In my clunker, the rubber bushing insert next to the firewall is rotten and is virtually collasped. Instead of spending $25 to get a new component, I think a cable would be much better, more responsive, et cet.
Has anyone done this in their W123 with the 617 engine? If so, can you please share? Pictures and donor car suggestions would be great. Advice, and whether or not you are happy with the change?
Thanks!
Thanks!
05-14-2011, 04:13 PM #2
Am will try to make one work for mine, Hope to have it pull on the passenger side of the valve cover so the cable doesn't have to do the big loop on the drivers side...
yankneck696
395
05-14-2011, 04:29 PM #3
Awe hell, just make it RHD...LOL
Ed
This post was last modified: 05-14-2011, 04:32 PM by yankneck696.
yankneck696
Ed
05-14-2011, 04:51 PM #4
Eh? RHD?
Eh? RHD?
yankneck696
395
05-14-2011, 05:55 PM #5
Right Hand Drive. Shorter cable that way.
Ed
yankneck696
Ed
05-14-2011, 11:40 PM #6
Ahhh there you go! haha
I looked at it today and with a cut and a weld, it can easily be done. I will do it, maybe in a week or two though
05-15-2011, 07:43 AM #7
I have a cable (bowden cable ??) that sits on top of the valve cover and it routes down on the passanger side. What does this do ? Do I need this ? Thanks.
Biohazard
Smokin like a champ!
376
05-15-2011, 09:42 AM #8
That cable controls transmission shift points, I would recommend keeping it. Smile
Biohazard
05-15-2011, 04:05 PM #9
Don't really use my cable because I shift the car manually anyway!
