No power off the start
Hey all My 1980 300sd just got a 1983 motor. I modded what was needed. I pulled the pump to replace gasket. Timed the crank and pump. Did the drip test.The problem i am having is when i depress the acc. pedal it takes a bit longer to get going. Turbo lag ? Not enough boost. But when it gets rolling is has a lot of pickup. I rotated the pump towards the motor about 4mm from the lil mark at pump mount. Very sluggish. Then i went 4mm away from motor. Seemed a lil better. Is the the right thing to do. Or could my turbo be full of carbon, blow off valve inop. What else can i do to the pump after the drip test to dial it in better. I am learning a lil at a time . Benz newbie. It is a slug now. Thanks Quinn
Is your alda connected to the manifold?
Quinn,
You should be drip timing the pump to 24 or 26 degrees BTDC. There is nothing else to do unless you open it up
(06-04-2011, 03:48 PM)Captain America Quinn,
(06-04-2011, 01:36 PM)led-panzer Is your alda connected to the manifold?
(06-04-2011, 05:07 PM)chach007(06-04-2011, 03:48 PM)Captain America Quinn,
I did the drip set up at 24 BTC. I fixed a few small fuel leaks. It is still crappy and i dont know about ALDA enough to know where and how to adjust it. The idle is really rough. shaking alot. The motor smoothes out at higher rpms . I'm stuck w/o a car till i figure it out but not having any luck. What could you guys tell me about the stamped mark on the front cover that the inj. pump mounts to and what if i'm a mm or two away from it. thanks
I really dont know much about ALDA. Idle shaking real bad. pump timed to 24 btc. Ok . I have crankshaft @ 24 degrees btc. Pump timed and installed and tightend up the the stamp marks. I do the drip test when the cam lobes are up and valves closed and # one cyl. should be tdc. Then i do the drip test . Or have crankshaft @ 24 degrees and do the drip test. or is it the same.
Ok hold on. There is only ONE way to time the pump.... Cylinder 1 @ 24 degrees BTDC at the crank... Yes both valves would be closed... Measuring the marks will do nothing for you, especially dependent on timing chain stretch. fuel should drip one drop per second roughly.
Is there smoke? If so, what color?
Is this the first time you have drivin with this 1982 617?
The bolt on the back of the pump is the rack damper... It helps reduce engine shake at idle. Try turning it in, if you go to far, it will be hard to start.
Have the valves been adjusted?
Plenty of fuel with clean filters?
sounds like the ALDA on top of the pump is adjusted very lean and it would dog until it made enough boost
There should be a big square thing on top of the injection pump with a line running to the intake manifold thats the ALDA
on top of it there should be a 10mm nut on a threaded shaft with a slat for a screw driver ion it loosen the nut turn the screw ccw like you are loosening it turn it gently if it stops don't force it any more! tighten the 10mm lock nut back down and it should increase off boost fueling! and help the turbo spool faster! It may be under a black cap
Hi,
first fix the rough idle and timing, then mess with ALDA.
How does it start? Do all cylinders fire up instantly?
If not check for fuel leaks again.
The small return lines between the injectors are dry?
As said before, filters are o.k.? valve clearance?
The rack damper has nothing to do with "rough" idle rather with "smooth" shaking at idle, don't turn it now.
How are your injectors/nozzles?
First get it running correctly then go into ALDA and other possible issues.
Tom
Listen to Tom. Do the basic adj. FIRST!! Also a stuck open egr valve can cause hard start,smoking,poor idle,lack of low end take off power. Easy test,engine off,install hose to egr,pull vac.,(can be done with out tools),Quickly pull hose from egr, should hear clack shut. Check both cold and hot .
(06-04-2011, 08:08 PM)Captain America Ok hold on. There is only ONE way to time the pump.... Cylinder 1 @ 24 degrees BTDC at the crank... Yes both valves would be closed... Measuring the marks will do nothing for you, especially dependent on timing chain stretch. fuel should drip one drop per second roughly.
