STD Other Projects road trip 2
road trip 2
road trip 2
Pages (2): 1 2 Next
06-11-2011, 02:40 PM #1
This car is way better than the last one. Not all rusty. Missing some stuff under the hood but overall way nicer.
[Image: IMG00517-20110611-1245.jpg]
06-12-2011, 08:39 AM #2
[Image: IMG_0387.jpg]
[Image: IMG_0390.jpg]
[Image: IMG_0392.jpg]
[Image: IMG_0391.jpg]
[Image: IMG_0388.jpg]
[Image: IMG_0396.jpg]
[Image: IMG_0393.jpg]
[Image: IMG_0394.jpg]
[Image: IMG_0395.jpg]
Supposed to be an '82 just like my last car but stuff is a little different.
Different tires, center console, turbo, etc.
06-12-2011, 08:48 AM #3
whats the ratchet strap for? broken air cleaner mounts?
Looks like a wonderful blank canvas Big Grin
06-12-2011, 09:28 AM #4
Yeah broken air cleaner mount. Maybe one day I can get rid of that ufo and have a long runner intake and exhaust header tied up to ball bearing turbo and a/w intercooler.
Wink
First project, put those mufflers in storage and put on the ole four foot pipe.
Wink
06-12-2011, 09:40 AM #5
sweet new car looks nice!
06-13-2011, 05:41 PM #6
(06-12-2011, 08:39 AM)larsalan ...
It appears from the accessories/vacuum lines you have an 1985 motor installed your 1982. I can confirm if we have the engine serial number and perhaps the transmission.
Nice looking car though. You can SEM vinyl dye your dash blue so it will match your interior better. http://www.worlduph.com/vinylmbzlate.htm
06-13-2011, 05:55 PM #7
That is quite a good guess.
It looks like it is from a smashed 85 then.
There is some weird vacuum thing on the turbo near the intake.
Also there is no air cond. and the hard line for it that crosses in front of the valve cover looks like it met a head-on collision.
Motor runs good and body looks nice. Title says it is a corrected/dup title.
Where is the engine serial? On the front of the block?
Will look for the trans # of the side by the pan.
This post was last modified: 06-13-2011, 06:03 PM by larsalan.
06-13-2011, 06:04 PM #8
(06-13-2011, 05:55 PM)larsalan ..
Yes that is the ARV - Air recirculating valve. Found on '84 cali and '85 cars. The accelerator linkages and Alda boost line makes it out as an '85.
06-24-2011, 10:04 PM #9
First valve adjustment went well, they adjusted easily into place. But as I put those fuel return lines back onto the valve cover where there is a little clip, I tore one open and ended up spilling probably 5 gallons of fuel on a 350 mile trip Sad huge mess and waste of $
Also, there is some alignment crap that makes the car shake at about 60mph+
PO says it is track arm bushing or some such. l'll have to address that right away.
And, there is some knocking in the motor that didn't seem to be there before and it's only about half time. Tried to crack each injector but that didn't seem to locate the problem.
Oh, that knock was there before and after the valve adjustment. The noise is what prompted the procedure. And each valve was pinned to the cam so I guess it was good to let in a little gap.
This post was last modified: 06-24-2011, 10:12 PM by larsalan.
06-25-2011, 05:27 PM #10
(06-24-2011, 10:04 PM)larsalan Also, there is some alignment crap that makes the car shake at about 60mph+
Yeah, ha.
Ive had 2 of these cars that shook like a MOFO from like 55-70ish, below or above that and they were fine. I never fixed the problem, and drove it like that for about a year. With no ill side effects besides scaring the crap out of passengers.
Yeah, ha.
06-25-2011, 08:29 PM #11
well of the bat, the front wheels were not at all balanced. I think now some replacement shocks and it will be quite nice. I was going just over 80 once the wheels were all balanced.
That knocking is the worst! I think I want to make one of those pop testers out of a bottle jack and have a try at tuning in the injectors. The motor for sure runs worst in just the few weeks I've had itSad
06-26-2011, 01:00 PM #12
Too stupid. I backed into a tree covered in brush today. Trying to park in the shade. Dented the trunk lid and had to replace the tail lens. Thankfully the body was sparred so all I need is the lid Sad
06-28-2011, 08:46 PM #13
ufo air filter housing is in the scrap pile. Got that fram 8037 and some abs pipe. Got a chance to feel the play on the turbo. This one is rock solid.
07-07-2011, 05:58 PM #14
This moody bitch won't shutoff now!!
Nothing infuriates me more. Driving about, stop at the atm, stop at the Chinese restaurant, stop at a friends house, get to the dog park and now she won't fucking stop!!
What seems to be the problem you bitch!
And it's raining and it's 95 degrees fuck it all.
07-07-2011, 08:36 PM #15
Let her run!
Let her run!
07-09-2011, 11:38 AM #16
Well, that was simple. The vac line to the fuel shutoff actuator had shaken its way loose.
07-09-2011, 09:56 PM #17
Ok, I need some diesel 102 lessons.
If I can get a few spare $ I might want to plumb up a FMIC
So, power comes from more air and more fuel. If the fuel is just staying stock and the turbo is stock then what will the intercooler do?
It means more air, right? Cause it will be more dense. Anyway running the intercooler should be an performance upgrade, right?
And what is the best size? Not a itsy bitsy one for a civic and not a big boy from a powerstroke.
Is all that volume in the intercooler going to put in a bit more lag?
yankneck696
395
07-10-2011, 03:40 AM #18
The intercooler should loower your intake temps, hence lower your EGTs, hence add longevity to your engine. Also, if you play with your pump, you will have that EGT buffer. It should not add much lag, as long as it is sized correctly. The only major issue is fitting it without hacking the bumper or looking stupid ;-)
yankneck696
07-10-2011, 06:27 AM #19
So what is proper size? And what is that based on, engine displacement, turbo airflow?
looks like they are all about 25-31 in wide
then there are heights like 5, 7, 11in
and the thickness of like 3-5in.
Eventually I will have to ask how to plump it too. Is there any point in having a 3in inlet/outlet if the turbo is more like 2in.
07-11-2011, 01:40 PM #20
What do I make of this, I have the alda backed out all the way and still no black smoke.
maybe it needs a shim too?
This post was last modified: 07-11-2011, 02:12 PM by larsalan.
Biohazard
Smokin like a champ!
376
07-11-2011, 03:18 PM #21
You can try just removing the ALDA from the injection pump, leaving the boost line connected. With no ALDA hooked up at all, see if you get any smoke. No black smoke currently could be as easy as you just have a clean intake manifold and the proper boost level already set.
For the intercooler, stay with a thinner model (2.5-3" thick), the thicker one looks cool but actually doesnt cool as well as the thin one. Also, if you can find a 2-2.5" in/out, that should be fine. If the in/out is 3", just neck it down to to fit a better size. With a stock pump, or even mildly tweaked stock pump, I don't think you are going to need a huge intercooler. Find the biggest one that will fit without having to hack stuff too bad. Just remember, the more air volume (IC size and tube size) the more it has to compress before getting boost. Even with a moderate IC, I doubt you will have too much lag.
Biohazard
08-08-2011, 10:51 AM #22
[Image: photo-1.jpg]
10-22-2011, 07:30 PM #23
With a FMIC on the way I am planning out the installation. I also have a new/old intake manifold all cleaned up.
I thought I would crank up the max boost on the wastegate. What amount of boost can this stock turbo make? How much should I turn it up to?
10-22-2011, 07:38 PM #24
Hey Larsalan,
Very nice looking car !!! Paint looks good ... congrats.
Hey Larsalan,
10-22-2011, 07:47 PM #25
Oh, thanks. Was just doing some paint today too. Blacked out the head light bezels. And reblacked the grill.
It's not all that great but I have fun Wink
So what about that boost? No egt gauge just trying not to have a melt down Wink
10-23-2011, 11:27 PM #26
Stock turbo? like 12lbs. 14 max
11-06-2011, 07:52 AM #27
Custom skid plate? Found this old tractor panel in my forest. Think I should clean it up and see what it would take to fit it under the motor with a few bolts, cutting, brackets, repainting or whatever.
The FMIC installation is on hold because it's going to take some body cutting and needs some connectors and pipes that a beaucoup bucks.
[Image: IMG_0692.jpg]
serverman777
11-12-2011, 03:19 PM #28
[img][Image: 0RoEi.jpg][/img]
there is that skid plate all mounted up and stuff
'84 300 SD w126 Race Car Wink
'85 500 SEL w126 Scraped
serverman777
11-13-2011, 02:13 PM #29
I want skid plates!!
serverman777
11-13-2011, 07:06 PM #30
@larsalan You should drill a hole where the drain is for the oil pan. For you can just reach up there and take out the plug with out removing the plate. Then you can add a few more blots Wink
serverman777
11-14-2011, 01:30 AM #31
I plan to do a whole belly pan on mine. From front to rear diff. Should work out pretty easy
11-14-2011, 04:07 PM #32
(11-06-2011, 07:52 AM)larsalan Custom skid plate? Found this old tractor panel in my forest. Think I should clean it up and see what it would take to fit it under the motor with a few bolts, cutting, brackets, repainting or whatever...
What are the dimensions of that plate?
Here is a shot of my w123 plate below. Dimensions of the plate itself (without the brackets are roughly 17inches front across, 13 inches rear across, 16.5 inches down the middle and 3.3mm thick.
(11-14-2011, 01:30 AM)Captain America I plan to do a whole belly pan on mine. From front to rear diff. Should work out pretty easy
You definitely need it. The pansy plate I have won't help you at all! LOL.
Be sure to post pics. Cool
This post was last modified: 11-14-2011, 04:11 PM by DeliveryValve.
11-14-2011, 04:50 PM #33
I have the same skid DV. But I am going to weld some plate to it for reinforcement, then continue it all the way to the back to protect the trans and rest of the drive train when I start off roading again haha
11-14-2011, 06:23 PM #34
Dimensions? I dunno. It's not so much a skid plate as a aerodynamics plate in my mind. The steel is thin and doesn't have those reinforcing ribs like yours. It was just something to do.
You can see it next to that shovel. We had to trim the back corners to let the steering shit move. Control arms or whatever they're called. I just have 2 bolts in it. One at the front and one at the rear. But, the leading edge is pretty well pinned into the body sheet metal.
11-14-2011, 07:10 PM #35
Are skid plates available commercially for w123's or are they a diy kind of thing??
11-14-2011, 07:19 PM #36
DV posted a pic of the stock one above. So theoretically you can get it from the dealer... most people stick to lucking into a used one or making one.
serverman777
11-14-2011, 09:23 PM #37
How much dose the stock ones cost?
serverman777
11-14-2011, 10:17 PM #38
My off-the-wall guess would be 300 or something.
11-14-2011, 10:44 PM #39
(11-14-2011, 10:17 PM)aaa My off-the-wall guess would be 300 or something.
Not quite that much.
Prices came down recently from prices a few years ago.
$92 @ the Peach
http://catalog.peachparts.com/searchItem.epc
And at World Impex.
http://www.worldimpex.com/parts/mercedes...93945.html
If the radiator support is available (which is said to be NLA), plus the skid plate, then maybe $300 including shipping.
This post was last modified: 11-14-2011, 10:45 PM by DeliveryValve.
$92 @ the Peach
And at World Impex.
mike-81-240d
more like mike-84-300d now
427
11-15-2011, 03:05 AM #40
(11-14-2011, 09:23 PM)serverman777 How much dose the stock ones cost?
The stock one they are talking about wont fit on your W126 though... Exclamation
mike-81-240d
serverman777
11-15-2011, 08:46 AM #41
(11-15-2011, 03:05 AM)mike-81-240d
Well thats dumb.....
serverman777
11-15-2011, 04:57 PM #42
Paid $90 for mine
[Image: attachment.php?aid=3655]
[Image: attachment.php?aid=3656]
Paid $90 for mine
11-15-2011, 06:31 PM #43
Mine's better.
Mine's better.
11-16-2011, 01:08 AM #44
So the Mercedes-built one just bolts right on? Or are there special brackets and stuff that are needed also
11-16-2011, 04:00 AM #45
The w126 plate is NLA.
Part number 1265200442, was about $140.00.
Both w123 and w126 skid plates bolt on to existing mounting points on the body.
W123 oil pan plate with radiator plate that is NLA.
This post was last modified: 11-16-2011, 04:02 AM by DeliveryValve.
mike-81-240d
427
11-17-2011, 01:34 AM #46
I have the oem W123 oil pan and radiator plates... Big Grin
mike-81-240d
04-07-2012, 06:00 PM #47
Well shit, now my heater core is dumping coolant all over the floor. If I just don't run the heater do you think I can let it ride for a while?
04-07-2012, 06:50 PM #48
I'd block the heater hose off, I think it'd continue leaking even with the heater off.
04-08-2012, 12:57 AM #49
Sounds like a plan for now. Anyway you know anymore about that? Is the supply hose on the driver's side of the block right over the oil filter?
Just like cut the heater core out of the loop? Run some heater hose in place of that part of the loop?
This post was last modified: 04-08-2012, 12:59 AM by larsalan.
04-08-2012, 03:36 AM #50
I would just put a ball valve in the heater loop some place, I think that would be the simplest solution. Then after you get your heater core problem fixed, it would still be there for emergencies in case you ever had a problem again
Pages (2): 1 2 Next
 25 Guest(s)
 25 Guest(s)
