STD Tuning Engine The next step for my wagon...
MTUPower
288
06-12-2011, 01:54 PM #1
I have come a bit of a plateau. I've installed the myna pump and now I need the next step. Please help me make that next step. My 1984 300TD with the normal 617-952 has an Blackstone (saab) intercooler right next to the reclocked stock turbo. It's cooled with air from the stock air intake location. The turbo is fed with a m117 air intake system beside the radiator going thru a GM 3.8 liter engine air filter box- which has a K&N pleated filter that is placed directly in front of it. The turbo puts out as much as 28 psi depending on the level I set the IP at. The previous setting with the maxed out stock IP was around 17. The exhaust manifold is coated similar to jet-hot. I have the VW AAZ two stage injectors popping at 150 bar with newer monark nozzles. Of course I have the egt and boost gauges. I run Mobil 1 diesel oil. The front end is lowered with vogtlands and HD's. You can see the pics in the car gallery- it's there.
What is my next step as far as the engine is concerned? I want more power on both the low and high end of the rpm range. I do not have time to step up a full VGT system, but have some money if someone wants to fabricate one and I install it. Help me spend the next $1000 with your suggestions.
This post was last modified: 06-12-2011, 01:56 PM by MTUPower.
MTUPower
06-12-2011, 02:49 PM #2
How bout an HE351CW. Should push more boost with less heat, plus it has a small exhaust housing so it won't be laggy.
led-panzer
06-12-2011, 03:14 PM #3
At the expense of the low end.
The ideal thing would be a 2359 or slightly bigger vnt. It's not really that much more difficult than a regular turbo swap
1985 300D 280,000 miles RIP
led-panzer
06-14-2011, 04:05 PM #4
Buy my HE341 Big Grin. It is just a wee bit smaller than the HE351.
Ditch the 3.8 GM filter, it does not flow enough. Welcome back.
MTUPower
288
06-15-2011, 09:07 AM #5
(06-14-2011, 04:05 PM)winmutt Buy my HE341 Big Grin. It is just a wee bit smaller than the HE351.
I know the flow rates for the 3.8 but it does have the higher flowing (but worse filtering) K&N. There is very little room for anything else and still have a cold air intake.
I'd love to have a VNT, but putting a system together is too time consuming for me right now. I'd buy a system if someone wants to make it and then install I it, but getting all the parts and engineering it is not in the cards for me.
This post was last modified: 06-15-2011, 03:02 PM by MTUPower.
MTUPower
06-15-2011, 08:33 PM #6
Next step. More air.
I wonder saab intercooler might be a restriction. Having it on a flow bench would tell.
I think a Cam swap will help. Contact Colt Cams http://coltcams.com/ to see what grind he can make for you.
http://www.superturbodiesel.com/std/show...?pid=10564
You might want to try a GT28R or better a GT30R ball bearing turbo for your lower end and not have to mess with the VNT.
If you can find a VNT setup, I think the GT2359v or better the GT2360v would be good for the car.
dieselboy
Rotatin 5500 times a minute
680
06-16-2011, 01:03 AM #7
Gt3076r turbo if you want some bottom end still and have some good flow. Personally with that much fuel I'd try a similar setup to what I have (hy35). I'd love a pump with bigger elements right now but I'm trying to leave my Sd at the point its at right now so can can keep putting money and time into my 242.
This post was last modified: 06-16-2011, 01:04 AM by dieselboy.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
06-16-2011, 01:14 AM #8
^^^ I'd do this..
http://cgi.ebay.com/ebaymotors/Brand-New..._500wt_956
http://cgi.ebay.com/ebaymotors/Genuine-G...458wt_1026
If I had over grand budget and didn't want to mess with a VNT.
This post was last modified: 06-16-2011, 01:24 AM by DeliveryValve.
^^^ I'd do this..
dieselboy
680
06-16-2011, 01:26 AM #9
Except for the easiness id go with the newer internally wastegated setup.
But that's like 1600$!! I paid 350$ for my hy35w that was professionally rebuilt.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
MTUPower
288
06-16-2011, 08:32 AM #10
(06-16-2011, 01:26 AM)dieselboy Except for the easiness id go with the newer internally wastegated setup.
Remember this is a daily driver, and I'd rather not put out too much smoke at lower rpms. Would the GT30 be too large and spool slow so that a good compromise would something a bit smaller?
MTUPower
MTUPower
288
06-18-2011, 10:07 PM #11
I have a stock exhaust- with just the rear muffler removed and replaced with straight pipe and a downturn. How much louder might it be with the center muffler gone also? Is it tough to increase the size of the exhaust with off the shelf parts and self assembly? That I can do. Where to get a larger flex-pipe?
MTUPower
06-18-2011, 10:49 PM #12
These cars really arnt tooo loud with a straight pipe. I would say go for it. You can always add a glasspack later if you dont like it.
How about a port and slight-polish job? How about polishing the pre-chambers? These probably arnt gonna be a major power gain, but id think it would definetly do somthing.
Along with a turbo upgrade, how about doing a intercooler setup like Dieselboys w116, front mount it so the intercooler is getting maximum airflow. Do you have a w115 intake manifold?? That would be a good idea. How about getting some headers welded up instead of a exhaust mani?
dieselboy
680
06-19-2011, 12:11 AM #13
Stock exhaust still?! I'd get a 3" on there and go with it. I had stock size straight piped and when I went to 3.5" I gained 5psi. If I was to do it again I'd do 3" with a single straight through small muffler at the back.
Then would be turbo.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
06-19-2011, 01:26 AM #14
(06-16-2011, 08:32 AM)MTUPower ... Would the GT30 be too large and spool slow so that a good compromise would something a bit smaller?
I personally think the GT30 ball bearing turbo is perfect for your application.
(06-18-2011, 10:07 PM)MTUPower ... Where to get a larger flex-pipe?
You'll have to make it. Any muffler/exhaust shop should have universal flex pipes that they can weld up.
This post was last modified: 06-19-2011, 01:27 AM by DeliveryValve.
dieselboy
680
06-19-2011, 12:27 PM #15
Yeah I think a gt30 would be perfect. These guy seem to be doing good to people http://www.mandrelexhaustsystems.com/servlet/StoreFront
This post was last modified: 06-19-2011, 12:29 PM by dieselboy.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
