STD Tuning Engine Blow off on a hx35 set up
W126Lover
Hx35 OM603
16
06-30-2011, 01:08 PM #1
I want to know is a blow off valve needed with a hx35 setup on a OM603.
W126Lover
06-30-2011, 02:32 PM #2
diesels have no need for a blow off valve since there is no throttle body
ConnClark
06-30-2011, 02:35 PM #3
In general blow off valves aren't need on diesels and the wastegate will handle everything just fine. ( The exception being to prevent surge during shifts if the turbo isn't sized and matched right).
ConnClark
W126Lover
Hx35 OM603
16
06-30-2011, 05:11 PM #4
Ok thanks. That's what I was thinking since the w140's don't have them.
W126Lover
06-30-2011, 05:52 PM #5
It would be very hard to hook one up! since there is no throttle body there is no direct vacuum source to open the blow off valve
It's main purpose is to dump the excess pressure so the turbo docent slow down during shifts on an engine when the throttle plate is closed
we have no need since there is no throttle clogging up the works
dieselboy
Rotatin 5500 times a minute
680
06-30-2011, 06:10 PM #6
Yes and no. How much boost you going to run?
There are alot of Mercedes diesels with factory recirculate valves and controllers.
We put on on a friends ford 6.0 because the vgt turbo isn't fast enough to respond when letting off.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
W126Lover
Hx35 OM603
16
06-30-2011, 06:16 PM #7
So then what's the part that seems to work like a blow off, on the inlet part of the turbo on 86,87 om603 engines?
I don't know how much psi I will run. I'm going to start at 18 psi and work my way up so to get it perfect.
This post was last modified: 06-30-2011, 06:21 PM by W126Lover.
W126Lover
06-30-2011, 06:44 PM #8
That would be the factory recirculation valve. Although it's not used for that. I keep forgetting what it was for though... they keep adding and removing it (there in 85, gone in 86, there in 87, gone later...).
 6 Guest(s)
 6 Guest(s)
