STD Tuning Engine looking for a certain type of air-water intercooler...
300D50
Graphite Moderator, ala RBMK
07-10-2011, 08:58 PM #1
I know I'm not crazy, and I HAVE seen these.
It's an air-water intercooler that looks like a chunk of regular charge piping, but has a bunch of straws that the air flows through, that are surrounded by the water.
I saw it on a website a few months back, had a black background iirc.
I'm not looking for one of those useless "we took a chunk of square core and shoved it in a section of tube" deals, or the box ones.
I also know it's not a laminova core.
I kept telling myself I'd bookmark it, but never did...
300D50
tomnik
07-10-2011, 10:52 PM #2
I think I saw something like that on LandCruisers (Australian manufacturer).
The 4.2 l also have a cross pipe over the valve cover like the 60x.
Tom
tomnik
Tom
300D50
07-10-2011, 11:23 PM #3
these were aftermarket, aluminum, and iirc anodized red or orange on the outside.
I'll look into the landcruiser setup
EDIT: Found the ones I think you're referring to Tom, those are made by "PWR" and aren't the ones I was looking at before.
EDIT: anti-double-post concatenated these, they were two separate posts...
[Image: starburst.jpg]
Found em!
Expensive as hell as well...
This post was last modified: 07-11-2011, 05:53 AM by 300D50.
300D50
Found em!
dieselboy
Rotatin 5500 times a minute
680
07-11-2011, 12:28 AM #4
Look like a transmission cooler on a big truck lol. But anodized.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
yankneck696
395
07-11-2011, 05:45 AM #5
By your description, sounds like a marine style heat exchanger. I am not sure how efficient it would be for cooling charge air. It's meant for cooling fluids. They sure flow good, though. I thought of using one years ago & talked to the diesel tech at the boat yard I worked at (formerly a jet/diesel Rolls Royce man) & he told me it would "Have to use bloody nitrogen to be worth the space".... Yeah, he is british.
Sorry, computer was slow to load the pic.
Ed
This post was last modified: 07-11-2011, 05:53 AM by yankneck696.
yankneck696
Ed
300D50
07-11-2011, 05:52 AM #6
I found em, the anti-double-post just shoved the posts together.
Edited the post for clarity.
300D50
yankneck696
395
07-11-2011, 06:08 AM #7
I don't really think that unit could be too efficient. The restriction at the inlet & having the body at the same diameter as the charge piping? With a marine heat exchanger, the diameter more than triples so as to not restrict flow.... It sure is pretty, though...
Check out http://www.sen-dure.com/ for ideas, products & ratings. The company you are referring to probably uses one of Sen Dure's cores & makes their own housing.
I would think that some form of disruption of airflow to allow for all of the air contacting the surface area would be nessecary for cooling efficiency.
Now, a marine heat exchanger might cool well if you use your air conditioning direct or to cool water flowing through.
Ed
yankneck696
Ed
07-11-2011, 01:25 PM #8
I know exactly what your talking about Walt. My buddy made a few as prototypes and wouldn't give me one haha (I wanted one for my car).
Yeah you look into one side of it and it looks like a bunch of small straws inside.
I wish I had a picture of it. I seem to remember seeing one around on the net too....
The design is similar to the Ford EGR cooler on the 6.0.
This post was last modified: 07-11-2011, 01:35 PM by Captain America.
tomnik
07-11-2011, 04:38 PM #9
this is what was in my mind:
http://www.turbonetics.com.au/3121/index.htm
Tom
tomnik
Tom
300D50
07-11-2011, 10:49 PM #10
Hm, just realized I should look into getting the supercharger fit onto the side of the block first, or at least running the calculations...
300D50
