STD Tuning Body Mods CLK rims?
CLK rims?
CLK rims?
04-23-2009, 09:25 PM #1
I don't know if this is the right place for this question, but I "happen" to have access to 4 16 inch CLK rims. Is it possible to mount them to a 123? Do I need spacers? I know the offset is different, but would the wider rim make up for it?
oel_brenner
04-23-2009, 10:07 PM #2
(04-23-2009, 09:25 PM)dropnosky I don't know if this is the right place for this question, but I "happen" to have access to 4 16 inch CLK rims. Is it possible to mount them to a 123? Do I need spacers? I know the offset is different, but would the wider rim make up for it?
pretty sure you will need spacers..
I have always liked that wheel... like a modern "bundt"
if you mount them.. take a photo.. I have always been curious how they would look
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
cars
trucks
boats
04-23-2009, 10:24 PM #3
That was the same reason I liked them! Some of the classic along with modern wheel size. I will certainly post a before and after pic when and if they fit.
05-02-2009, 02:24 PM #4
Well, technically, CLK rims will fit on the 123 without modifications, especially on the rear.
However, at least with this specific 16 inch rim, there is maybe a 8th of an inch clearance between the tie rods and the edge on the front, too close for comfort, and actually no issues on the rear except that the stock wheel lugs are too long for both.
Ive ordered up 4 spacers which should alleviate both these problems.
05-04-2009, 05:22 PM #5
1/8" is more than I have.
05-04-2009, 07:06 PM #6
I am a bit worried about clearance just in case of road debris being kicked up into the gap, possibly knocking off the wheel weights, or tearing the boot on the tie rod. Its probably just my inner wuss showing through.
MB TECH
05-05-2009, 12:05 PM #7
On mine I have 255/30R19 on the front and 285/35R19 on the rear, the front has about the width of a screwdriver blade
from the tire and the steering knuckle. I have had this setup on for almost ten thousand miles and experienced no problems. You should be ok
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
05-08-2009, 07:48 PM #8
Mounted them with a set of super cheap used 205/55 R16 snow tires on, which the PO reccomended as a good size, but I think I will go slightly larger when I actually put some new all season tires on it. Im pretty pleased with how it looks. Handles a little better on corners as well.
MB TECH
05-11-2009, 07:22 AM #9
Those look good on there.
1960 220SE
MB TECH
1960 220SE
05-11-2009, 09:32 AM #10
They do, when I get the car painted I am going to get a set.
07-09-2009, 10:29 AM #11
Have to take em off until I have the cash for some all season tires. These wide soft snow tires are KILLING the fuel economy on this car. Its unbelievable. My old tires are tall, thin, and have 20% tread life left. The closer to bald, the better the fuel economy.
This post was last modified: 07-09-2009, 10:30 AM by JB3.
GileadGarage
07-09-2009, 11:51 PM #12
(07-09-2009, 10:29 AM)dropnosky Have to take em off until I have the cash for some all season tires. These wide soft snow tires are KILLING the fuel economy on this car. Its unbelievable. My old tires are tall, thin, and have 20% tread life left. The closer to bald, the better the fuel economy.
i really like these wheels. I used 5MM hubcentric spacers since the stock alloy ligs were to long and will wreck your ebrake. I have 215/50/16's on em which fit with no rubbing, even with the 1"lower.
[Image: 010.jpg]
GileadGarage
[Image: 010.jpg]
07-10-2009, 08:21 AM #13
I like that size tire! Looks good on the wagon.
GileadGarage
07-10-2009, 05:20 PM #14
(07-10-2009, 08:21 AM)dropnosky I like that size tire! Looks good on the wagon.
thanks, I was not sure what to get but I'm happy w/ 215's. Apparently 225's fit ok too. I'm happy with the coil chop, went w/ 1 coil. Rides/handles great, like a different car since I rebuilt the frontend/brakes. I'm entering it in a hillclimb race just for fun since there is an alt fuel class at this event.
Your car looks nice, amazing for 350K! I did the 2:88 as well, what a nice upgrade for the highway!
GileadGarage
tantank79
T3-45
109
08-19-2009, 11:32 PM #15
I had always heard rumors of these wheels being pretty lightweight so before mounting them up tomorrow, I figured I would weigh one.
I used a double-beam balance medical scale, so it should be pretty accurate.
And the verdict is...
14.0 lb !!
Has anyone else weighed these wheels? If so, let us know what your results were.
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
14.0 lb !!
-Brian
1983 300TD
1982 240D
1981 280TE
08-20-2009, 11:40 AM #16
bigger question what did the stock alloys weigh? vs the stock steelies w hub caps vs new 16" alloys
tantank79
T3-45
109
08-20-2009, 11:20 PM #17
Funny you should ask that!
I mounted them up at work this evening where I have access to a VERY accurate, calibrated, digital scale. (Used for weighing fuel in fuel economy testing)
CLK 16x7: 14.2xx lb
stock 14" Bundt: 13.8xx lb
(The scale read out to three decimals, but I can't remember them.)
I figured the Bundt would be fairly light due to its small size, but I didn't think it would be lighter than the CLK wheel!
Since I was swapping tires off of a set of 02 C230 Kompressor, dual 5 spoke wheels onto my CLK wheels, I took the opportunity to weight them as well.
C230 Kompressor 16x7 dual 5 spoke: 18.3xx lb
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
CLK 16x7: 14.2xx lb
-Brian
1983 300TD
1982 240D
1981 280TE
jughead
10-20-2009, 09:31 AM #18
(07-09-2009, 11:51 PM)GileadGarage
[Image: 010.jpg]
I got the same wheels for my 82 300sd. Will 5mm spacers work for me as well?
jughead
[Image: 010.jpg]
biobenz617
11-29-2009, 03:14 PM #19
What about spacers on the front? Did you use 5mm up there too? How did they fit?
I tried 10mm hubcentric H&R spacers on my CLK rims, but the spacers don't fit on the front due to the hub sticking out so far. I ended up using 25mm spacers, but still had to mill out the insides of the hubcentric extension. I tore up one of my tires on the fender lip because they stick out so far up front now. The 25mm spacers look awesome in the rear though and fit great! I have Vogtland lowering springs.
biobenz617
Jtn190D
MERCEDES DIESEL POWER!
192
12-19-2009, 05:08 PM #20
Would these fit on my 190d?
Jtn190D
Rudolf_Diesel
Ask me if I care...
12-19-2009, 07:31 PM #21
A little off topic, but WTF are snow tiresBig Grin We don't have those in sunny California. It was 80 degrees today.
Rudolf_Diesel
MB TECH
12-20-2009, 04:35 PM #22
its like a really soft compound tire, kind of like driving on pencil erasers. Ya when I moved from Wisconsin to Mississippi I got some puzzled looks when I was talking about snow tires.
1960 220SE
MB TECH
1960 220SE
10-25-2010, 11:59 AM #23
(12-19-2009, 05:08 PM)Jtn190D Would these fit on my 190d?
yes! Big Grin and they look good
http://www.superturbodiesel.com/std/my-8...l#pid19723
mike-81-240d
more like mike-84-300d now
427
11-07-2010, 11:25 PM #24
Hey drop you should put these CLK's on your new turbo d. Wink
mike-81-240d
Joe Reitman
09-10-2011, 01:19 PM #25
I am having trouble finding hubcentric spacers for my 300cd. any suggestions?
John 3:16; John 14:6
'83 300CD 115,XXX miles lowered
'06 Dodge 3500 Cummins modded
'82 Yamaha 465 Enduro Street Legal
[Image: IMG_1047.jpg]
Joe Reitman
mike-81-240d
427
09-10-2011, 06:21 PM #26
Ebay.
mike-81-240d
Ebay.
Joe Reitman
09-12-2011, 05:08 PM #27
Thanks.
Joe Reitman
Thanks.
NGARover
12-26-2011, 10:36 AM #28
(09-12-2011, 05:08 PM)Joe Reitman Thanks.
What mine looks like....
Now I need to work on lowering the car a little
This post was last modified: 12-26-2011, 10:37 AM by NGARover.
NGARover
12-28-2011, 04:56 AM #29
Lower a Lot!
Lower a Lot!
 18 Guest(s)
 18 Guest(s)
