STD Tuning Engine Cylinder Head Gasket w124 300 turbo OM603 which one?
  • 1 Vote(s) - 1 Average
justcruisin
02-21-2011, 08:26 PM #1
Ok, ready to replace the head gasket due to an oil leak to the timing chain.
I would like to experiment a little with the turbopressure so it might be wise to use another head gasket than original?
Anyone know which one? Any mods needed? Other tips to make this 603 faster, the cilinderhead has to come off so easy to do some mods.
This post was last modified: 08-23-2011, 10:30 AM by winmutt.
justcruisin
jonbobshinigin
02-22-2011, 12:23 AM #2
Someone else will chime in her with more details but...
If I recall correctly, a 606 head gasket is MLS which has metal in it and can bus used on a 603 but some drilling has to be done first. I too am wanting to get a game plan ready for when I replace mine :-)
1987 300TDT - 260,000 Miles
jonbobshinigin
jeemu
&quot;some people do, some people talk.&quot;
457
02-23-2011, 05:08 PM #3
What is your engine setup and how much boost you use?
jeemu
justcruisin
02-23-2011, 10:32 PM #4
It's still stock, want to raise the pressure of the turbo and screw the ip for more diesel.
Maybe later a bigger turbo?
Because the head hasket is broken it might be wise to mount a better/different one.
Thanks for helping out a newbie.
justcruisin
jeemu
457
02-28-2011, 12:28 PM #6
Somewhere I saw a thread that showed where the holes had to be placed. Anyone know what I am talking about?
jeemu
457
02-28-2011, 06:05 PM #7
(02-28-2011, 12:28 PM)winmutt Somewhere I saw a thread that showed where the holes had to be placed. Anyone know what I am talking about?
Not need any thread when you have old and new gasket.
jeemu
08-23-2011, 08:49 AM #8
Jeemu, you said use VHT copper gasket in http://hevosvoima.com/foorumi/viewtopic.php?f=33&t=125
Where do you suggest placing it? Around the cylinders?
jeemu
457
08-23-2011, 11:53 AM #9
(08-23-2011, 08:49 AM)winmutt Jeemu, you said use VHT copper gasket in http://hevosvoima.com/foorumi/viewtopic.php?f=33&t=125
Spay the gasket on it. I disassemble gasket and layers and spray all layers.
jeemu
08-23-2011, 12:04 PM #10
Interesting. do you have a link to what you use. Here copper sealant gasket is not sprayable.
jeemu
457
08-24-2011, 01:38 AM #11
(08-23-2011, 12:04 PM)winmutt Interesting. do you have a link to what you use. Here copper sealant gasket is not sprayable.
Hi. It is this what we use http://www.vhtpaint.com/coppergasketcement.html
Also Mopar has good spray gasket sealant. That i use now
jeemu
jonbobshinigin
08-24-2011, 10:58 AM #12
So then we would take a 606 gasket and drill the appropriate hole out, and then spray it with this?
jonbobshinigin
08-24-2011, 11:00 AM #13
(08-24-2011, 10:58 AM)jonbobshinigin So then we would take a 606 gasket and drill the appropriate hole out, and then spray it with this?
He said he actually seperates the layers for the headgasket and then sprays this inbetween. I think that is a bit overkill for my needs.
Jeemu, do you also spray the mating faces of the gasket with this stuff?
jeemu
457
08-24-2011, 12:47 PM #14
(08-24-2011, 11:00 AM)winmutt
At firs we sprayed only on top and bottom of gasket, but then we started to paint all layers.
Here is sprayed only top and bottom layer. It glue gasket on the block.
[Image: img1655134.jpg]
This post was last modified: 08-24-2011, 12:48 PM by jeemu.
jeemu
08-24-2011, 02:46 PM #15
I see more than one different hole on these gaskets when they're on top of each other.
This post was last modified: 08-24-2011, 02:47 PM by aaa.
08-24-2011, 03:34 PM #16
Compare to the head, not all are needed:
[Image: 322366d1280442778-om603-22-cylinder-head...g_0027.jpg]
 11 Guest(s)
 11 Guest(s)
