STD Tuning Suspension loan me your w123 sls pump
propigskinSLS
08-25-2011, 05:53 AM #1
I am making a block off plate for the sls pump on a w123. If you mail me a w123 sls pump (I will provide a shipping label for free) , I will return it along with a NEW blockoff plate for free for your time....
Email me below if interested....
Thanks,
Erik
propigskin@aol.com
slsconversion.com
propigskinSLS
Thanks,
Erik
propigskin@aol.com
slsconversion.com
capflya
Dreaming of a VNT
309
08-28-2011, 11:05 PM #2
I actually made a plate to block it off... I put the engine in my car and found out after it has a bad knock so I ended up pulling it... the plate is maybe 1/16 or 1/8" aluminum I think... it was whatever I found laying around here that was big enough to cover the hole. If you want it you're welcome to have it. You could use it as a template if you want to make something better/stronger. If the engine would have run better I probably would have taken it off and made something a little stronger to block it off.
I can either mail it to you, or if you want to meet me next weekend I'll be down in the loma linda area and could bring it with me. Let me know
-David
capflya
-David
