Installing a turbo oil feed on a 617 n/a
As it says in the title whats the best way to supply oil the a turbo when fitting one to a 617 n/a?
The way ive done it so far is with a t-piece on the oil warning light switch on the back of the oil filter housing,
As in the this picture:
https://lh5.googleusercontent.com/-o05UL...CT1349.JPG
The problem I seem to be having with this is when the engine gets very hot the oil pressure drops so that at idle the oil light comes on, my thinking on this is because theres a t-piece on the pressure switch its reading low?
Any one any ideas?
617 n/a and 617a oil filter housing are different to allow for turbo feed, any one know what stt and the like done for a turbo oil supply?
non turbo
http://www.neoriginal.ru/cat/mb/part__2_...32_617_932
turbo, part no 146 is for turbo oil supply
(09-07-2011, 05:38 PM)aaa What vehicle is this?
The rear plate on the oil filter housing unbolts
bolt up a turbo one from a 300d turbo and it good to go at least that's what I did on my 240d turbo
I actually replace the whole oil filter housing before I realized the only difference was the rear plate on it
(09-07-2011, 06:17 PM)aaa Would a restriction on the turbo line help? What pressure is that sensor set to go off at anyways, maybe you can change that out.
(09-08-2011, 09:07 AM)willbhere4u The rear plate on the oil filter housing unbolts
That is a badass G wagon!
(09-08-2011, 03:49 PM)Captain America That is a badass G wagon!
Do you have any videos!?! More pictures???
(09-09-2011, 04:47 PM)Captain America Do you have any videos!?! More pictures???
(09-11-2011, 06:49 AM)aaa So why not get a whole 300SD oil filter housing?
Also, if the pressure sensor's that sensitive I wouldn't be surprised if it set off on factory turbo 617, I'm sure I've seen less than 1.4 bar before.
I swapped a the oil filter housing and backing plate off of a turbo 617 on to a non turbo 616
After doing the swap I realized that the oil filter housings where identical with the same part number and I could have just swapped the back plate and gasket.
check out my build it has some pics http://www.superturbodiesel.com/std/Thre...240d+turbo
THE G WAGON IS SO SICK!!!!!!!
(09-14-2011, 12:01 PM)winmutt The "NA" filter housing you show is the same as the turbo ones here. I will be happy to send you a turbo housing back part.
Has anyone got a dead turbo engine lying around that they would sell the cover plate off the oil filter housing?
Its no 95 here, http://www.neoriginal.ru/cat/mb/part__2_...32_617_932
Or this is what it looks like: (pic stolen from willbhere4u's build thread)
(09-24-2011, 05:28 PM)aaa I assume you want a 300sd cover plate, not a 300d one.
(09-25-2011, 03:33 PM)aaa The 300SD one has a fitting for an electric oil pressure sensor, the 300D has a fitting for a oil line for the manual oil pressure gauge.
