STD Tuning Engine 96-98 w140 300 td- 270/320 cdi conversion?
pizdameti
09-22-2011, 11:36 AM #1
hey everybody im new!
im looking to buy a s300 td (it came with om606) and thought on doing it. now i wondered if its relevantly an easy swap. considering the 96-98 already has the elec' 722.6 tranny, how the rest of the elec' are matchable to the om61x cdi cars? in terms of cluster, sensors modules, esp, etc etc....
thanks!
pizdameti
thanks!
tomnik
09-22-2011, 11:55 AM #2
Hi,
what you can do is to swap the entire engine and tranny with complete wiring and ECU from a donor car.
The 606 is already the best engine for the W140, in my opinion.
Tom
tomnik
Hi,
Tom
pizdameti
09-24-2011, 01:11 PM #3
yeh but thats what im asking- what parts are already found in the w140 that the cdi ecu and CAN needs? if all the things are already in, then it will be an easy swap an although the 606 is great- you cant beat the cdi efficiency....
pizdameti
randomdude
09-26-2011, 02:45 PM #4
man, that would be a sweet car, with a sweet swap! hope you get it all figured out!
sorry to thread jack, but has anyone swapped a cdi into a w123?
cars? what cars? WHERE???
randomdude
Boatbuilder
MSc
40
10-13-2011, 04:05 AM #5
(09-24-2011, 01:11 PM)pizdameti yeh but thats what im asking- what parts are already found in the w140 that the cdi ecu and CAN needs? if all the things are already in, then it will be an easy swap an although the 606 is great- you cant beat the cdi efficiency....
Hi, you need the original wiring loom because of all the engine sensors.
Get it preferably from a car without automatic gearbox. You also need the original key, ignition lock , steering lock and original ECU because all these units are communicating with the ECU in order to "open" it up .
The wiring diagram from the donor car is also needed because you need to build in some relays and diodes in order to have it working. Good luck with the project. The CDI engines are very good. 6 cyl the best beast.
Boatbuilder
10-13-2011, 09:12 AM #6
Will the CDI get better mileage than the om606? The om606 is defiantly capable of a lot more power
