compressing pistons on bendix calipers?
i changed my front pads this weekend, and when going to re-install the new pads of course i needed to compress the pistons. my car has the bendix dual piston (non-floating) calipers, and there wasn't really enough space to squeeze in a C clamp to do the job. i took my Cclamp and used an angle grinder to cut the top off the clamp off right above the fixed pad. it took about 1/2 or 3/4 " off the clamp and it was just BARELY enough to get it to fit in between the pistons to compress them. and what do you know, while compressing the last piston, the heat from grinding off the top of the clamp weakend the metal and the clamp snaped in half .
there has to be an easier way. never had a w123 before, whats the secret tool needed to make compressing the pistons easier than pulling teeth???
thanks in advance.
where the heck did rotors come from? you dont touch the rotor when compressing caliper pistons.
I also use a prybar. Works great for me. I'm 17, 5ft 11, 130lbs and I've done brakes on three w123's with no sweat.
On my recently-installed Bendix fronts I used two 10-inch Vise-Grips to compress the inner side and that was plenty easy. Probably could do it with only one Vise-Grip, but I'm the cautious type. Once the caliper is off, the pistons can be compressed all the way in (so you can fit the new pads in) by hand if you have strong thumbs (easier on your thumbs if you place an old (but clean it up first) pad across the piston). Helps if you loosen the brake fluid reservoir cap, so the air can displace (otherwise you're working against compressed air). You should bleed the brakes (actually, you should pour-and-bleed enough fresh brake fluid from a never-before-opened new can through to flush the entire line between the master cylinder and caliper. Pour-and-bleed-through until the bleeded-out fluid is clear, then another two fluid ounces to make sure.) every time you change pads. Bleeding should be done on a zero-humidity day (brake fluid has a strong appetite for atmospheric water, and water in your brake cylinder+line+piston is a big no-no. Don't leave the cap off the brake fluid can any longer than you have to.). Don't forget to re-tighten the reservoir cap when you're done.
(09-26-2011, 08:59 PM)randomdude where the heck did rotors come from? you dont touch the rotor when compressing caliper pistons.
(09-27-2011, 10:27 AM)JustPassinThru Where did you find the dual-piston Bendix? So far I've only seen single-piston ones. ...
(09-27-2011, 02:49 PM)DeliveryValve(09-27-2011, 10:27 AM)JustPassinThru Where did you find the dual-piston Bendix? So far I've only seen single-piston ones. ...You serious? I don't think I ever seen a single piston caliper for the w123 or w126. In fact if you want a Bendix first Gen w126 dual piston caliper, I have a good set right now. Make me an offer.
