STD Tuning Engine om605 up to 350(hp)
om605 up to 350(hp)
om605 up to 350(hp)
only_diesel
10-25-2011, 06:03 AM #1
Hi everybody, i‘am from Lithuania, so sorry for my wrongly english language.
About VAG groups diesel engine (TDI) performance I know everything, i have done some projects, but it is to little to me.
Now i wanna bought c250 w202 mercedes with om605 turbocharged engine, and upgrade +-350(hp). About turbocharger, manifold and intercooler i know something (use holset hy35 or something else) but i don't know about fuel system. What pump‘s elements is in stock this models car? If i want 350(hp) what fuel pump is better, mechanical or electrical? If needs bigger element, where i can get them (ebay?) and how much it cost? need change nozzles?
So if you can, tell me all story about om605 performance, because in my country no one not working with mercedes engines.
Thanks
only_diesel
Thanks
Savitas
10-25-2011, 07:57 AM #2
(10-25-2011, 06:03 AM)only_diesel Hi everybody, i‘am from Lithuania, so sorry for my wrongly english language.
Thanks
Hi,
don't be so sure Wink
Electrical fuel pump means a lot of problem and no solutions in our country. You should take mechanical IP from older 5 cylinder MB diesel engine. To your power goal it is enough to use stock elements you have in OM605 IP and modified delivery valves. There is no need to use others fuel nozzles.
Good luck Wink
This post was last modified: 10-25-2011, 08:16 AM by Savitas.
Savitas
Thanks
Hi,
Good luck Wink
only_diesel
10-25-2011, 03:59 PM #3
can i use om602,961 fuel pump? how about pump's sprocket? everything bolt on? Rolleyes
only_diesel
Savitas
10-26-2011, 12:10 AM #4
(10-25-2011, 03:59 PM)only_diesel can i use om602,961 fuel pump? how about pump's sprocket? everything bolt on? Rolleyes
Yes, you can use IP from OM602 engines.
Savitas
tomnik
10-26-2011, 11:51 PM #5
(10-25-2011, 06:03 AM)only_diesel So if you can, tell me all story about om605 performance, because in my country no one not working with mercedes engines.
"Kross Data" in Riga.
if this is not too far away.
Tom
tomnik
Tom
only_diesel
10-27-2011, 11:45 AM #6
(10-26-2011, 11:51 PM)tomnik
Tom
little bit too far
only_diesel
Tom
little bit too far
ritvarsx
10-27-2011, 01:17 PM #7
Tom
They are in Latvia? What are they doing? I can`t find them!
ritvarsx
Tom
tomnik
10-28-2011, 12:06 AM #8
in Riga.
They are in progress of doing a pump for Kota.
Tom
tomnik
in Riga.
Tom
kotka
10-29-2011, 02:22 AM #9
I will give u some update when pump is installed on my om606. I see it happening sometime in late Nov / early Dec.
this is the photo so far
[attachment=5136]
(10-27-2011, 01:17 PM)ritvarsx
Tom
[attachment=5134][attachment=5134][attachment=5134]
kotka
[attachment=5136]
Tom
